April 4, 201411 yr I would like to build an EA 71 rally engine for competition use in VHC. To be noted that accordingly to the F.I.A. homologation form of the Leone of 70s(A22L,A31L,A32L,A33L,A26L)are permitted only the EA 63 and EA 71 engines. Because of those types of engine are very rare,here in Greece,I would like to collect all possible infos,experiences,suggestions,etc, before starting building it. I have in mind to machining the intake ports of the heads to accept twin WEBER carbs,one twin on each head. I would like to know,also,if the EA 63 heads are most preffered than those of the EA 71 ones. Furthermore I would like to know in what models I could find 5gear gearbox,compatible with the EA 71 engine. In the F.I.A. homologation form of the time I saw that there is 5gear gearbox with the following ratios: 1st : 3.31 (43/13) 2nd : 2.53 (38/15) 3rd : 1.96 (45/23) 4th : 1.52 (41/27) 5th : 1.03 (35/34) and final drive(CWP) : 4.13 (33/8). Could i found those ratios in some model? Edited April 4, 201411 yr by 1000 Pistes
April 7, 201411 yr 5th gear would be a FWD box,but unless you can swap in the newer awd stuff it would still be FWD unless its on gravel.
April 7, 201411 yr Author what type of 5speed gearbox(from what model) I could mount on the eA 71 engine,always for FWD car?
April 8, 201411 yr what type of 5speed gearbox(from what model) I could mount on the eA 71 engine,always for FWD car? A Subaru gsr(coupe) 1.4 or a GFT(2 door hard top) or GFTS 1.4 I'm not sure what model, but you might ask this person what the chassis tag says the gearbox is: http://saojuliaofigueiradafoz.olx.pt/subaru-gsr-1-4-1975-iid-444508251 Edited April 8, 201411 yr by Legacy RallyGuy
April 8, 201411 yr Author Only those, EA 63 type, was equipped with 5speed gearbox? Some other with EA 71 engine compatible?
April 9, 201411 yr Only those, EA 63 type, was equipped with 5speed gearbox? Some other with EA 71 engine compatible? Perhaps the GFT had a 5spd as well, mated up to the EA71
April 9, 201411 yr In Australia the GSR only ever came with a 4 speed gearbox, only the hardtop was equipped with the 5 speed. Very rare transmission as not many hardtops would have been sold and certainly not many have survived!
April 9, 201411 yr Author Some other 5speed gearbox coming from the late(after the 1979) Leones,to be compatible with the EA 71 engine?
April 9, 201411 yr Where have you found your information on the Leones so far? Do you have documents? I'd like to try to cross-reference with some Baja racing setups.
April 10, 201411 yr There were plenty of 77-79 EA71 FWD 5 speeds. Those are you best bet to go with. The FE had a taller final drive ratio than the others so not ideal for rally really but good for top speed.
April 10, 201411 yr When the Vintage Subarus roamed the planet, the majority of the country adopted the 55 MPH Speed limit was in place across the US (signed into law in 1974). Automotive Manufacturers then built, powered, and geared for the new National speed limit. Making engineering changes that brought maximum efficiency at anything below 55 MPH. Bursts of speed were factored in, but sustained and prolonged running at those speeds was not considered. Anything over 55 is considered "Overspeed conditions" for any vintage vehicle (such as our little Subaru). American vehicles seem to be able to hold up better, but Foreign imports would be up on the current vehicle requirements and would have built to the legal standards of the day. Wear and tear accelerates at our current freeway speeds. (75 MPH on the interstates here, with 85 accepted in some of the Southwestern states) a 1970s vintage Subaru running an EA71 through an automatic or a fourspeed would be SHRIEKING at those speeds. Yes, it could do it...but I doubt it would hold up for any length of time. (and FORGET about your mileage figures being anything other than horrid) Now the question, Is there a regear kit or an overdrive available? Not that pushing an EA71 to power such tall gearing would be any advantage. Granted, we run "outdated" vehicles that have been superseded many times over. Still, any ideas of anyone has been tinkering in this area? inquisitively, Timothy
April 10, 201411 yr Author Where have you found your information on the Leones so far? Do you have documents? I'd like to try to cross-reference with some Baja racing setups. Let me know if you would like knowing something about tthe old SUBARUs FIA homologation forms to pm you.it.
April 11, 201411 yr Author You DO NOT want an EA63 EA71 , for sure. Good luck. OK,thank you . Could you,please,to let me know if you have got some manuals,etc in pdf form,concerning the ff1 and the first generation of LEONEs ? It could be very useful to me.
February 24, 201511 yr Author Sure , as I get the chance I will. any news about the parts manuals????
February 25, 201511 yr Snow , much snow , and ice .... Winter hit good this February but I'll check as soon as I can.
