January 14, 201511 yr Author I had to cut the boot retainer off of the linkage rod otherwise it would not clear the driveline. Then I had to cut back the rubber bellows section so it didn't rub on the driveline. That's why I added some additional layers of plastic and insulation to help keep noise and moisture out of the inside. The rest is just stock bits and pieces that I have saved over the years. I'm not sure what model that shifter trim came from. I guess I lucked out finding a combination that fits and looks good. I tried to give enough pictures, but I will add some more soon. Thank you for looking
February 14, 201511 yr Author ^^^ I would like to help if you have any questions! Too bad I can't come over and play Can you share a picture of your Subaru? I would like to see it! Edited February 14, 201511 yr by Crazyeights
February 19, 201511 yr http://www.ultimatesubaru.org/forum/topic/151809-1993-loyale-build/Thats my whip! Nothing happening right now with it just sitting, need to get my motorcycle figured out first and then will get to work on this.Seems like there might be an xt6 in Bellingham I may go raid for parts and do the 5 lug swap as the first big upgrade with new suspension.
March 9, 20206 yr Author I am just about ready to put the EJ22T in my Loyale. This step is about 5 years overdue! The wiring is finally done. I am going to need a down pipe from the turbo to the rest of the exhaust. Is there an "off the shelf" down pipe from some other Subaru model that will work? I have an EJ22T turbo flange if I have to have one custom made. I also have a stock EA82T down pipe but it won't fit on the 22T's turbo. Any ideas short of having it towed to the exhaust shop? Thanks for any advice. Edited March 9, 20206 yr by Crazyeights
April 11, 20205 yr Late reply, but generally any factory dump pipe will work. Build your exhaust from the end of that. Cheers Bennie
April 13, 20205 yr On 4/11/2020 at 6:01 AM, Crazyeights said: Thank you! I have the flange and downturn of an aftermarket downpipe if you'd like that to start your custom downpipe. Located near Seattle, happy to ship it to you.
April 14, 20205 yr Author On 4/13/2020 at 10:09 AM, carfreak85 said: I have the flange and downturn of an aftermarket downpipe if you'd like that to start your custom downpipe. Located near Seattle, happy to ship it to you. That's really nice of you. Do you have a picture of it? How much do you want for it?
April 15, 20205 yr Author I picked this one up, do you think it will work? I am having trouble finding a flange to match the oval shaped port on the lower side.
