Tat2Brat Posted May 17, 2014 Share Posted May 17, 2014 I cant seem to get the cyl. heads off of my spare ea81 I dont want to hurt the heads but its stuck in place Cant get rocker assembly hard ware off but head bolts are out Rods are able to wiggle around tried some different solvents but no go What gives? Any suggestions to safely remove the heads Quote Link to comment Share on other sites More sharing options...
sumoco Posted May 17, 2014 Share Posted May 17, 2014 Hit them with a rubber mallet Quote Link to comment Share on other sites More sharing options...
Tat2Brat Posted May 17, 2014 Author Share Posted May 17, 2014 yeah did that too even got my wooden 15 pound gallagher-esque sledge hammer and nothing Quote Link to comment Share on other sites More sharing options...
TallonX Posted May 17, 2014 Share Posted May 17, 2014 Put the spark plugs in an roll it over by hand, just make sure you have 2 helpers to catch em or just thread the head bolts back in a bit Quote Link to comment Share on other sites More sharing options...
ruparts Posted May 18, 2014 Share Posted May 18, 2014 hi, are you sure you didn't overlook a head bolt that is still holding it?? Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted May 18, 2014 Share Posted May 18, 2014 Look 3 more times for hidden or missed fasteners The head may also be glued to the studs with rusty corrosion type stuff. Try flipping the block up on it's side (studs up) and soak each stud area with LOTS of Deep Creep, or PB Blaster or something. Be careful and patient if it's a good engine. Quote Link to comment Share on other sites More sharing options...
