warmblood58 Posted January 17, 2016 Share Posted January 17, 2016 Hello all, I removed my FI harness for repairs and concerned that I may not have them fitted properly to the correct injector. I am not worried about correct side as there is an obvious ground correction that orients this harness. That being said, how do I identify the FI connections correctly? Engine is a '94 EJ22 out of a Legacy. Thank you! Quote Link to comment Share on other sites More sharing options...
warmblood58 Posted January 17, 2016 Author Share Posted January 17, 2016 Looking to correctly match the correct connector to the correct injector Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 18, 2016 Share Posted January 18, 2016 Look for a wire diagram for your year. Injectors are labeled 1-4 on the diagram and the ground wire will be a different color for each injector. 2 Quote Link to comment Share on other sites More sharing options...
warmblood58 Posted January 18, 2016 Author Share Posted January 18, 2016 Thanks, now , anyone have a wiring diagram for a '94 Legacy? Quote Link to comment Share on other sites More sharing options...
ocei77 Posted January 18, 2016 Share Posted January 18, 2016 FSM is available. New Gen FAQ Sticky 2nd page under my name. If the same as 97: 4 LBlue, 3 L Red, 2 L Grn, 1 Brown. Double check. O. Quote Link to comment Share on other sites More sharing options...
warmblood58 Posted January 18, 2016 Author Share Posted January 18, 2016 You the man! Thank you! Quote Link to comment Share on other sites More sharing options...
wtdash Posted January 18, 2016 Share Posted January 18, 2016 Also, there should be a white (?) label/sticker on the front connector #1 and #2. Td Quote Link to comment Share on other sites More sharing options...
warmblood58 Posted January 18, 2016 Author Share Posted January 18, 2016 Also, there should be a white (?) label/sticker on the front connector #1 and #2. Td Thank you! Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 18, 2016 Share Posted January 18, 2016 If you get really in a jam I have a running '94 Legacy 2.2L that I could take a look at, it's just kind of cold and dark out at the moment haha. 1 Quote Link to comment Share on other sites More sharing options...
warmblood58 Posted January 19, 2016 Author Share Posted January 19, 2016 If you get really in a jam I have a running '94 Legacy 2.2L that I could take a look at, it's just kind of cold and dark out at the moment haha. So far, it seems that a brown ground wire is common for most years for #1 which then automatically establishes #3. What color wires do you have for #2 and #4? Thank you! Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 20, 2016 Share Posted January 20, 2016 What color wires do you have for #2 and #4? Thank you!3---4 1---2 radiator It was harder to see in there than I hoped since there's some loom over the wires plus the wires are dirty/dusty. 4 definitely has a yellow with a red stripe. The other 4 wire was a darker color to be honest hard to tell because of the dirt looked like brown with a blue stripe possibly. 2 looked like green as one of the wires 1 had yellow with a red stripe for a wire (like 4 did too!) and yes brown as the other wire as you mentioned. 3 was blue with a white stripe and I didn't see the other too well. Quote Link to comment Share on other sites More sharing options...
warmblood58 Posted January 20, 2016 Author Share Posted January 20, 2016 3---4 1---2 radiator It was harder to see in there than I hoped since there's some loom over the wires plus the wires are dirty/dusty. 4 definitely has a yellow with a red stripe. The other 4 wire was a darker color to be honest hard to tell because of the dirt looked like brown with a blue stripe possibly. 2 looked like green as one of the wires 1 had yellow with a red stripe for a wire (like 4 did too!) and yes brown as the other wire as you mentioned. 3 was blue with a white stripe and I didn't see the other too well. Hey, thank you, that really helps! Thank you for taking the time! Quote Link to comment Share on other sites More sharing options...
