May 22, 20169 yr Hi old friends. It's been awhile since I posted on here. I'm trying to work out if my customised standard air box on a Weber will fit under the hood of my Brumby/BRAT. The hood is currently not on the car so can anyone take a photo looking across from one fender to the other across the air box? This will give me an idea of mine will actually work. I would add a photo of what I have but this site won't let me upload one off my phone. Edited May 22, 20169 yr by Phizinza
May 22, 20169 yr Get a piece of wood and put it across the strut towers, then from this to the radiator support. Or put the spare tyre back in. If you're below these then you should be good. Why not put the hood back on? It's not that hard
May 22, 20169 yr Author I want to leave it off while I get the wiring and fuel sorted. Mines above the level line but I know for a fact there's a bit more room to play with under the hood I just can't remember how much as it was over a year ago when I started this project.
May 22, 20169 yr well, if you know how high twins sit, I run a custom air intake sitting on the normal part of the carb for air box to sit. It is made of 50mm high, 100 wide and about 280mm long, central and clears the bonnet undersides, not even rub in extreme moments.
May 23, 20169 yr Did you modify the stock air cleaner to fit the weber as was done in this other post? http://www.ultimatesubaru.org/forum/topic/142864-1978-subaru-brat-from-death-to-life-and-everything-in-between/page-7?do=findComment&comment=1279470 Ed
May 23, 20169 yr Author Heres what I've got...It's an ea81 airbox on a weber on top a customer manifold bolted to an EJ.
June 18, 20169 yr Author So I put the hood on today and it clears, along with my custom strut tops, lucky!
June 18, 20169 yr ... It's an ea81 airbox on a weber on top a customer manifold bolted to an EJ. Could you, Please, share Photos + Details regarding such adaptation? Sounds pretty interesting. Kind Regards.
June 18, 20169 yr Author As I'm on my phone and I can't upload images here its probably easier to read this thread here http://offroadingsubarus.com/forum/index.php?topic=1247.0
