1997reduxe Posted July 8, 2016 Share Posted July 8, 2016 Hey all.Been a while. I was wondering, I was looking at an 05 Legacy GT 2.5It appears the turbo is going on the car. I wondered is it feasible to run this car this way till I could get it fixed? Is that an expensive fix? I would have to basically replace the turbo? Just wondering. Thanks for any possible help. DanGood weekend all. Quote Link to comment Share on other sites More sharing options...
matt167 Posted July 8, 2016 Share Posted July 8, 2016 Do you want to replace a $2-300 turbo or a $3k engine? Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted July 8, 2016 Share Posted July 8, 2016 If you let the turbo go on those cars you will be replacing the engine shortly thereafter. Replace the turbo, and replace the banjo bolt in the back of the passenger side head that feeds the turbo and avcs system. Those models have filter screens in them that get clogged over time and starve the turbo of oil causing shaft bearing damage which leads to the turbo seizing and snapping the shaft. Tons of shrapnel gets circulated through the engine and within 3-500 miles you have a knocking rod. 1 Quote Link to comment Share on other sites More sharing options...
1997reduxe Posted July 8, 2016 Author Share Posted July 8, 2016 ah ok. thanks a lot. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 8, 2016 Share Posted July 8, 2016 $200-300? People wish is was that cheap... To have a shop replace the turbo, all three hoses, remove the banjo bolt filter, removal and cleaning of the oil pan, it's more like $2200... If it's failing, stop driving it. It can go from $2200 to $8500 real quick. I'm only in the middle of doing one myself and have another one waiting for me to start on it. 1 Quote Link to comment Share on other sites More sharing options...
subarubrat Posted July 8, 2016 Share Posted July 8, 2016 If it is the same turbo as the one used on the 04 Baja I have a good one (taken off for upgrade) $300 shipped, TD04 if I recall. Quote Link to comment Share on other sites More sharing options...
matt167 Posted July 9, 2016 Share Posted July 9, 2016 (edited) $200-300? People wish is was that cheap... To have a shop replace the turbo, all three hoses, remove the banjo bolt filter, removal and cleaning of the oil pan, it's more like $2200... If it's failing, stop driving it. It can go from $2200 to $8500 real quick. I'm only in the middle of doing one myself and have another one waiting for me to start on it. It's that cheap if you do it yourself. give or take the small parts. providing the turbo has not blown up Edited July 9, 2016 by matt167 Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 9, 2016 Share Posted July 9, 2016 With what parts? Unless you use a cheap rebuilt turbo, it'll never be that cheap. A new turbo from Subaru is roughly $1200 just by itself, then factor in 3 hoses, 2 gaskets, a banjo bolt with crush gaskets and you're pushing $1300. Just in parts. But hey, I only do this for a living. If you want to run cheap parts, you'll be doing it again. Or end up with other issues. Just my $.02 1 Quote Link to comment Share on other sites More sharing options...
Bushwick Posted July 10, 2016 Share Posted July 10, 2016 With what parts? Unless you use a cheap rebuilt turbo, it'll never be that cheap. A new turbo from Subaru is roughly $1200 just by itself, then factor in 3 hoses, 2 gaskets, a banjo bolt with crush gaskets and you're pushing $1300. Just in parts. But hey, I only do this for a living. If you want to run cheap parts, you'll be doing it again. Or end up with other issues. Just my $.02 If you catch the turbo quick enough, you can remove it, buy new bearings for $35 (if a GTxx Garrett can also upgrade to a 360 thrust plate) then ship JUST the rotating assembly (with or w/o the housing) and get it balanced at a place like G-Pop for $70. If compressor wheel is bad, can add $50 for replacement roughly. If Turbine is bad, around $125~. Doing the math, you can get a freshly rebuilt turbo for very little, and yes it'll be done "right". Quote Link to comment Share on other sites More sharing options...
ccrinc Posted July 10, 2016 Share Posted July 10, 2016 Blouch Turbo in Lebanon, PA. Excellent quality reman'd turbos. Good prices. Have used them for years. Emily Quote Link to comment Share on other sites More sharing options...
