March 15, 20179 yr I have been getting really lousy start-ups on winter mornings. A friend said I needed to put a can of dry gas in, I don't recall doing so. What are the best option on this?
March 15, 20179 yr ThosL, Fuel line deicer/fuel line antifreeze (I believe its wood alcohol?) is what is being referred to. A small container added to a full tank of fuel will absorb any water in your fuel tank/lines and allow it to burn. I always add one to the tanks of my vehicles during the winter, about half way through the winter season, even though I've never had a fuel line freeze up issue. Another thing to decrease the possibility of water in the first place, is to always keep the fuel tank as full as possible. This leaves little room for air in the tank to condense the water from it into the fuel.
March 16, 20179 yr Can you elaborate on the really lousy part? Lots of things can cause cold starting problems, but there are too many versions of "lousy cold start" to say what's causing your problem without having some more info.
March 16, 20179 yr ^^^ what FF said dew/moisture on old plug wires can cause issues. Failed Engine temp Sensor could as well.
March 16, 20179 yr My one experience with water in the fuel showed up on the highway. If your only trouble is starting, it's probably something else.
March 16, 20179 yr Author Cold or wet in the morning, vehicle runs crappy until it really warms up. Check engine light flashes. Once it warms up in 15 minutes or longer it runs well.
March 16, 20179 yr If the check engine light flashes when it is running I would see if there are any codes stored. I agree if it just happens when you first start it then I'd be looking somewhere besides water in the fuel.
March 16, 20179 yr while it's wamed-up an idling well, you could use a plant mister to spray water on/near each plug wire and see if it causes stumbling. Some folks say if you do that at night you can see arcing. seems like plug wires or coil. the moisture is driven-off after the engine bay warms up.
March 17, 20179 yr check your idle air control valve if it is dirty or sticking it will not run right or possibly not start. last time i ran in to that issue after i ran it by cracking the throttle body enough for the car to run it ran fine once it warmed up a little bit
March 17, 20179 yr while it's wamed-up an idling well, you could use a plant mister to spray water on/near each plug wire and see if it causes stumbling. Some folks say if you do that at night you can see arcing. seems like plug wires or coil. the moisture is driven-off after the engine bay warms up. I had a 56 Chevy that you could almost read from all the light that from the arcing that was going on under the hood from the spark plug wires.
March 18, 20179 yr Author Very likely it's the plug wires. I will have to buy a set of those for around $30.
March 18, 20179 yr do not get cheap aftermarket, they are known to not work reliably on Subarus. OEM is best. NGK or Denso will probably be $25 to $50 on am,azon depending on what part number you need. Edited March 18, 20179 yr by 1 Lucky Texan
March 19, 20179 yr If you are running a fuel that is say around 10% ethenol or higher, is dry gas gonna be of any benefit. Just saying.
March 19, 20179 yr I happen to come across this: Dry gas - Wikipedia https://en.wikipedia.org/wiki/Dry_gas Dry gas. Drygas is an alcohol-based additive used in automobiles to prevent any water in the fuel from freezing, or to restore combustive power togasoline spoiled by water. ... The belief that dry gas is not needed because of the significant amount of ethanol is largely true because ethanol is a drying agent.
March 27, 20179 yr Author I ran a test at Auto Zone: It came back as ignition coil, based on: PO301 PO302 PO303 PO304 PO400 egr P1100 low input. I'm thinking wires as when it warms up it runs well. I don't think I've changed them since I bought it, a year ago.
