Sapper 157 Posted May 10, 2017 Share Posted May 10, 2017 So awhile ago I replaced my old four blade electric fan with a flex-a-light 10 blade fan. The one problem is that since installing the fan, I have been unable to use my block heater, because the fan offers no room to plug the cord into the element in the block. I was thinking, if I reversed it and put it on the front of the radiator and rewired it so it pushed air instead of pulled, that would solve my block heater issue. anybody ever tried this? Any potential/theoretical problems that could develop by doing this? Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted May 10, 2017 Share Posted May 10, 2017 Common practice on ej swapped vehicles, there isn't enough room to mount them between the engine and radiator so they end up going with pushers. 1 Quote Link to comment Share on other sites More sharing options...
nipper Posted May 10, 2017 Share Posted May 10, 2017 They can be pushers or pullers, Just put it where there is clearance. 1 Quote Link to comment Share on other sites More sharing options...
Sapper 157 Posted May 10, 2017 Author Share Posted May 10, 2017 Awesome. Thanks for the fast response! Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 10, 2017 Share Posted May 10, 2017 A fan is generally more efficient as a puller, but it's a fairly minor loss to switch it to a pusher. Check the instructions for your particular fan, some of them have directional blades, which has to be removed from the motor and flipped. 1 Quote Link to comment Share on other sites More sharing options...
