August 17, 20178 yr Aye, We all know these things, these clips or (clip/nuts) that are receivers of bolts........... they are mounted all over the place.... You see them holding the electric fans to the radiator or even can be see holding the wiper wash bottle to a mounting bracket..... The ones I am specifically interested in , are the ones that hold the electric fans to the radiator....... 1998 subaru outback..... THEN a ten mm bolts runs through the plastic frame of the fan to the radiator..... where this (clip/nut) allows you to thead into... the ten mm bolts THUS, holding on the radiator fan to the radiator securely........ WHAT ARE THESE CALLED?????? WHERE DO I GET NEW ONES? should be able to buy a pack of them... Thanks, MICKY
August 17, 20178 yr They are called Speed Nuts. Go to the 80's GM isle at the wrecking yard. They used 6x1.0 speed nuts all over the place. GD
August 17, 20178 yr ^ What GD said. If you are feeling all Subaru the OEM part number is 45119AC001 J-Nut. $2 each from your local dealer. You can try here: http://cliphouse.com/MetricUJNuts.aspx Edited August 17, 20178 yr by Mike104
August 17, 20178 yr eBay. Keep searching through there till you find the best deal. You can probably get 50 for ten bucks with free shipping.
August 18, 20178 yr Author Thanks! The 80's GM isle...... that is great...... Funny, I gotta go there for a tailight.. today Thanks! for the other source too.... much appreciated..... Mike104::: thanks for the link yeah, that works.....jnuts unuts and EBAY......
