2001 Forester with bad strut tower
Saw an ad for a 2001 forester with an issue.  I don't know if this is a common thing.
Hard fix?
it says it's automatic,  drive train is all good.
Driver side Rear strut tower is bad.     Rear tire is leaning.
Is this common?  Is there a kit?
I'm guessing it's rusted bad.  Salt on roads.
Any help is appreciated.  Yes I know you could tell me more with a picture, I haven't seen it first hand myself yet.  I'm just gauging whether its worth it.   133k miles,   Asking $700
Guess it depends on what is bad.  If it's the strut simply a parts remove and replace.  If it's the mounting area would need some fabrication skills to cut out bad parts and weld in some new metal.
Is there a body panel to cut out and weld in?  Or is this a total re fabrication out of whatever metal?
Subaru does, or did supply new strut towers and they are spot welded in. Would be a large job but doable if the metal around the tower is good
Judging from the Advertisement, its rust.  No mention of wreck,  and body looks fine from outside
Messaging the owner she said the problem is that the metal is rusted  where it mounts
Part is available (I2)
51600FC101 (or other superseding part numbers dealer will use VIN to determine correct one)
Around $400 though.
http://parts.subaru.com/p/WHEEL-APRON-COMPLETE-REAR-RIGHT/49502852/51600FC051.html
May be possible to cut offending part or section of from pull and pay yard and weld in, but again depends on how bad the area is rusted
Edited by Mike104
Funny but I saw that car on craigslist a while ago!
Ifant imagine even considering it. If that's rusted so probably is the exhaust fuel filler brake lines fuel lines brakes other strut towers quarter panels.
They sent me pictures on Facebook. I cant post them here   idk...
anyway,, the rust isn't around the top,, you can see the metal split inside the wheel well behind the strut..    and inside the car they have the carpet panel pulled back and it seems to be coming apart there too.  But not the strut cap area.
May also take a look at the rear crossmember and underside of the body for rust that may affect structural integrity
