December 28, 20178 yr I didn't see any starter contacts listed for old gen stuff. will the EJ kits work for old gen or XT6?
December 28, 20178 yr as in the copper bits inside a starter motor? Cant even recall if the copper bits are inside the solenoid. Never had to rebuild one. Touch wood !!
December 28, 20178 yr I got mine from the dealer, but I suspect you can get along with any on-line set. Probably a lot less expensive. While you're making updates you might also want to add a starter relay. Sooner than later it is going to need that too.
December 29, 20178 yr I've just cut and bent & drilled them from a sheet of 1/16" thick copper I have.The contacts are in the solenoid.I made mine a bit wider than the one that wore out to give it more contact area. Have not had to do it for quite a while.
