GOOD TIRES FOR A 2011 SUBARU FORESTER
Yup, pretty much the northeast, the all weather tires are perfect.
  • Replies 68
  • Views 9.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Are you in Montco or Delco Springfield? BJ's, Costco and NTB all sell name brands at good prices. I put both Michelin or Bridgestone on our Subies as replacements for years and been happy wi
  • 1 Lucky Texan
    1 Lucky Texan
    if you need a good 'compromise' tire, you might look at Pirelli Cinturato . They helped us survive white-out conditions returning from Colorado a few years ago in winter storm 'Ursa' . They are not no
  • if your tires are wearing evenly, I wouldn't bother. If you have an inner or outer shoulder worn more than the rest then get an allignment
Matt.
   I appreciate the help. Question: for all wheel drive what good millage and not so good millage to get out of tires. I have been getting 30k out of tires for my 2011 Subaru Forester.
 Also for my Toyota Corolla what is good mileage to get out of a set of tires. Thanks.
If your Subaru is in good allignment, I would expect 40k miles to be about the max you'll get and 25k miles the least.. Somewhere around double that for a FWD Corolla. Figure 40-50k miles per set on a FWD
Now when should a vehicle get an alignment. That is something I never new. I thought you get an alignment every year or do you only get an alignment as needed.
I always got my vehicles aligned each year. I just do not know. Thanks.
If tires are wearing good/ even treadwear, you don't need one. Some elect to get alignment checked with every set of tires.
Edited by matt167
Copy that - if they're wearing fine now then you don't need one.  If you think about it - if alignment magically "went out" frequently - you'd have issues even getting an alignment once a year or with every tire change - if the alignment went out shortly after those times you'd be driving 10 months or years with bad alignment.  As it happens, that's not really common.
Rough roads and driving conditions can be more detrimental on alignment than really good roads, vehicle conditions, and light vehicle use.
I routinely ran 100,000 miles without even thinking about alignments in maryland and georgia on well maintained surfaces.  Now in WV with far worse roads I tend to see more alignment issues.
it's wise to consider the vehicle use (roads, towing, work, loads, aggressiveness) and proactively keep an eye on how they're wearing somewhat regularly.
Matt
  I totally understand you are no expert. Did you ever hear that if a vehicle is pulling to the right or left that is a sign you need an alignment
  You are a tire installer the works for a place that sell tires. Thanks.
4 minutes ago, bull6791 said:
Matt
alignment is one possibility for pulling left or right. But also, you can have a hung brake and not know it, and there is also the possibility that a tire has a broken belt or is under pressure, and causing a pull due to high rolling resistance..
BTW I used to do allignments, but hated doing them so I'm glad I don't do them where I'm at
Matt
  Question. You used to do alignments before. Why won’t alignment places just do an alignment check. In my area of pa the places that do alignments will not do just a check. They say you get an alignment or not. If we are going through all the trouble to hook up the equipment we are almost done the alignment so you are getting it. No buddy in my area will wast their time to hook up equipment for a check. So answer me why can’t these places in my area just do an alignment check.
 Matt also I will be getting new tires. Should i get an alignment or not. Thanks again for the help
takes a while to set up an allignment rack and often you'll find something just a smidge out of spec to where, your that close it might as well be done and at that point take your money for an alignment..
I had a buddy who recently went out of business who did alignment checks for $20, and $60 for the alignment which is dirt cheap here as well as having a low labor rate. He closed his business because he wasn't making enough. But he had a large customer base.
I am getting new tires. Should I get an alignment with my new tires or not.
Matt
  What kind of work do you do.
   That is how you judge if you need an alignment inner or outer shoulder wear
Best advice would be to buy a tread depth gauge. Walmart even sells them now for a dollar or so, or any auto parts store. any more than 2/32" variance or so and I would want an alignment. Check in 3 places or otherwise just look for uneven wear
That would be for second from left. If your tires are flat spotted ( left ) then you need shocks/ struts or you got your tires at discount automart and the balance is way out.
  • 2 weeks later...
Matt
   I am getting an alignment and cooper tires for my 2011 Subaru Forester. Thanks.
Matt
  I got cooper cs5 grand touring tires.
   What is the difference between touring and grand touring tires. Thanks.
Grand touring is a name that some use but basically meaningless. Touring tires/ grand touring tires are just basically highway tread..
We sell a lot of the Master craft version of the CS5, the LSR grand touring. There a good highway tire
Matt
  What is the difference between touring grand touring and ultra grand touring tires.
   Also are they good tires for non highway local stop and go driving. Thanks.
Just go and visit a (or a few) tyre specialists/dealers and talk with them knowing the info that Matt and other members have contributed in here. They’ll be able to give you an upfront answer and you can ask more questions with a much quicker turn around in reply time.
I think you’re over thinking this and really just need to get a new set of tyres. I’ve been reading since the first post and now it seems you’ve got the tyre you want but then nit pick for something else.
It took me less than ten minutes on the phone to decide on my tyre choice. And I always get an alignment with new tyres, always! Alignments are cheap insurance to get the most life (=distance) from your tyre.
Bennie
