November 26, 20196 yr So I have an 88 gl wagon and it needs a new driveshaft, I also have a 86gl sedan, will the driveshaft from the sedan work in the wagon? Because I really dont want to spend 400 bucks on a new one haha
November 26, 20196 yr If it’s a front driveshaft for the front end and both are carb then yes. Front and rear shafts are not interchangeable. Cheers Bennie
November 26, 20196 yr Author So what youre saying is that I cant use the rear drive shaft from the transmission to the axle from the sedan 86 and put it in the wagon 88
November 26, 20196 yr 2 hours ago, Lifted glwagon said: So what youre saying is that I cant use the rear drive shaft from the transmission to the axle from the sedan 86 and put it in the wagon 88 No, in other parts of the world, a "driveshaft" is the axle shaft from the transmission/diff out to the hub, so that's what he's talking about. As long as it's an EA82 sedan ('85+ in the US) with the same transmission, yes, it'll work just fine.
November 27, 20196 yr Author Thats what I was thinking because I measured the wheelbase length wise on both cars and it matches haha thanks a bunch guys
November 27, 20196 yr Hehehe... tailshaft/prop shaft. Now I get what you were asking! What Numchux said Cheers Bennie
