Naked Buell Posted March 7, 2020 Share Posted March 7, 2020 Hey guys, I have a 2.2T in my Brat. It has the stock plastic expansion tank on the engine. I had the stock Brat radiator modified for the coolant hoses for the Ej motor. I have the small coolant line coming off the drivers side of the engine that originally went into the white overflow tank, which I don't have any room for. Can I just take that coolant line and connect it right to the Brat radiator cap overflow nipple? Or do I need that overflow tank? The engine came out of an auto tranny, I am not sure what the manual versions had. Does anyone have a pic or manual diagram? I was thinking, if I just fill the Brat radiator to its normal tab level inside the radiator and then connect the line from the motor to the cap nipple, would that be okay? Quote Link to comment Share on other sites More sharing options...
heartless Posted March 7, 2020 Share Posted March 7, 2020 the overflow bottle does not have to sit in the stock location, but it should have one somewhere. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted March 8, 2020 Share Posted March 8, 2020 If you connect that line to the radiator’s overflow line from the filler cap, you’ll just be pressurising this line from both ends. You’ll need to add an overflow bottle and have both of these lines end in the bottle. Or run two bottles - one for each line. Then you’ll know which cap is doing all the work Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted March 9, 2020 Share Posted March 9, 2020 What are you using for a down pipe from the turbo to the rest of the exhaust? Is there a bolt on pipe from some other model that will work? Quote Link to comment Share on other sites More sharing options...
Naked Buell Posted March 9, 2020 Author Share Posted March 9, 2020 I kept the stock SS down pipe off turbo, and then it is going to be custom new exhaust all the way out, MagnaFlow. I had one on my 02 Wrx. It sounded awesome. 1 Quote Link to comment Share on other sites More sharing options...
