best headgasket kit for ea82t
15 hours ago, turbodog said:
i need a new headgasket, is fel-pro the go 2? has anyone had good luck with others?
what he said - FP headgaskets, the rest from dealer.  the FP kit won't have the reinforced metal orings for the lower corner of the cam carrier, or none that I've ever seen have it anyway.
intake manifold, tstat, water pump, exhaust are all better quality from dealer.  sometimes I might use FP valve cover gaskets but mostly just because if they do fail again it's just a minor oil leak and they're easy to replace.  i don't want that risk or work load for intake mani or coolant.
Edited by idosubaru
