November 3, 20214 yr 86,,GL carbed stalls out ,fueling problems ,fuel pump or clogged up fuel tank stalls out, oh yeah it's a 4/4 wheel wagon any easier way to clean out fuel tank, than removing ,looks like a pain in the rear PLEASE HELP ,
November 3, 20214 yr Before doing anything that involved, I'd tee in a fuel pressure gauge in the line to the carb.
November 3, 20214 yr Auto parts stores have fuel pressure test gauges. The one I have also can test vacuum. A brass T that matches the hose ID, some clamps and a piece of fuel line. Carb fuel pressure should be single digit number of psi.
November 4, 20214 yr 11 hours ago, Ned P Pritchard said: 86,,GL carbed stalls out ,fueling problems ,fuel pump or clogged up fuel tank stalls out, oh yeah it's a 4/4 wheel wagon any easier way to clean out fuel tank, than removing ,looks like a pain in the rear PLEASE HELP , what story is the fuel filter telling you?
November 21, 20214 yr Author fuel filter is clean seems fuel line from tank is resricted only a trickle from tank ran a piece of wire thru and only a trickle coming out of pipe almost full tank what to take tank out and clean or replace need help please what is best option ,
November 21, 20214 yr Remove tank cap, blow compressed air from pump line (but not through pump) back to tank, clean out what you can via the fuel gauge sender unit hole. Can do same for fuel line from engine bay back to the pump, but again, not through the pump or the filters. This should give you a clear line to work with, or show up where the blockage might be located. Cheers Bennie
November 21, 20214 yr The other thing to check is that the fuel cutout relay is working properly. It could be priming with ignition on but cutting the pump while the engine runs because it’s not getting the signal to say the engine is running - or the relay box thing is dead. Common on the Brat era vehicles, don’t think it’s common on the L series. Cheers Bennie
November 21, 20214 yr hmmm, what Bennie says above. I started the metal pipe only blow backwards process at the front and worked my way to the empty tank. I used an old fire extinguisher to transport the compressed air from petrol station to home. It was only on the final section from fuel pump to tank that I heard, then found the rusty crud that was lining the inside of the metal line. EA81 tanks are easier to see this as their sender unit are mounted on the back side. I had it out to see a pristine clean , empty tank, until the blow back landed. I dragged it out by wire and rag tool. EA82 won't be as easy.
November 22, 20214 yr Author where is sending unit access point where does fuel line enter tank hard to tell just a look at it,NP
November 22, 20214 yr Author car starts runs well until you try l stall out .starved for fuel wait and restarts repeat same?
November 24, 20214 yr On 11/22/2021 at 11:24 AM, Ned P Pritchard said: pictures of tank sending unit access point? In floor of boot/trunk/cargo area. Should be a little sliver plate off centre to the RHS. Cheers Bennie
