pontoontodd Posted March 1 Share Posted March 1 I am wondering how difficult it would be to add cruise control to a 1998 Impreza Outback Sport (5MT if it matters). Couldn't find this discussed anywhere. I have another Impreza that I think has all the parts I'd need to swap over - steering wheel, main button, module under hood, module under dash. So I guess my main question is, would a car without cruise have all the wiring and connectors in place? Quote Link to comment Share on other sites More sharing options...
pontoontodd Posted March 1 Author Share Posted March 1 For what it's worth I've now read that all the wiring should be there, module is different between manual and automatic. 1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted May 24 Share Posted May 24 Any updates on this Todd? There’s this write up for the Gen3, some of it might be relevant to other models too: http://www.subyclub.com/topic/12666-diy-installretrofit-cruise-control-to-3gen-liberty/ Cheers Bennie Quote Link to comment Share on other sites More sharing options...
wtdash Posted June 22 Share Posted June 22 Here's what I did - and the link with pics: https://www.rs25.com/threads/1998-2-2l-questions.185798/page-2#post-2968169 Installed on '96 Impreza LX w/an AT trans. Get the following parts: 1. Cruise control module - must match your trans -AT or MT (they are labeled on the module) - the PLUG/connector IS ALREADY THERE and is taped up under the dash just above your left foot. I mounted it to a spot under the dash w/zip ties. 2. Dash CRUISE switch - the PLUG/connector IS ALREADY THERE - just remove the 4 screws on the console piece around the gauges, pop-off the 'blank', plug in the wiring connector and insert the new switch. 3. Brake switch - the cruise brake switch is PLUG/connector IS ALREADY THERE taped just above the brake pedal- just swap switches - Note the threads/adjustment of the existing switch to match the new one...or your brake lights may not work or cruise may not easily disengage. 4. Actuator/Vacuum hose/T-connector/Brackets - under hood connects to throttle cable. PLUG/connector IS ALREADY THERE taped to the harness near the passenger side strut tower. It mounts in the stock location- the Forester brackets worked on my Impreza, too. Use the T-connector to splice into your vac lines on the intake manifold. 5. Steering wheel switch/lever (there is no need to remove the steering wheel!) - 2 star screws to remove to get the airbag off (read up on here about what to do to not set it off - I just removed the Neg battery cable, pumped the brakes a few times), remove the right side of the spring loaded horn actuator, pop-out the blank for the switch to pass thru on the steering wheel, swap the wiring for the switch - uses the same connectors - no splicing necessary, put it back together.... I got all my parts from a '98 Forester and they worked EXCEPT for 2 issues: 1. The cable from the actuator was too short, but it'll still work. 2. The steering wheel switch doesn't work for the Resume or Cancel features, but everything else works. I may try swapping in an 'age-appropriate' Impreza module to see if that fixes it. Quote Link to comment Share on other sites More sharing options...
