SuspiciousPizza Posted September 28 Share Posted September 28 I'm doing a top end rebuild and reseal on an EA82 that'd been sitting in a car in the woods for 20+ years. The heads need resurfacing but once they're ready to go back on, I'm curious about oiling the head bolts. What's your preferred method and oil/lube? My first thought was engine oil but how best to apply? Use an oiler bottle? Just dunk the threads and shake off a bit of the excess? Tangentially, for the Felpro head gaskets (they're what I had laying around from a reseal kit I bought) they say they're 'permatorque' do they REALLY not need to be retorqued? Would going through the FSM -60°, oil threads, retorque, repeat really not make a difference? I find that hard to believe. The engine was stored with oil in the pan, I'd like to fully clean out the pan to get all the old oil and crud out of there. Should I use something like diesel to flush out the pan? Any preferred methods? I'd like to flush out the coolant passages with distilled water once the engine is back together (before installing). I was thinking of using an aquarium pump in a 5 gallon bucket with some sort of filter/strainer system, removing the thermostat, and letting it run overnight to get all the old nasties out of there. Or would it be just worth flushing the system with a chemical flush while driving around? Any thoughts are appreciated, y'all have more experience than I do. Thanks :] Link to comment Share on other sites More sharing options...
el_freddo Posted September 29 Share Posted September 29 (edited) I was a long time ago that I did an EA82 headgasket job - I don’t recall there being instructions to back off the head bolts in the process! Just use engine oil, nothing special required. If you dip the first 5mm of thread that should give you heaps of oil to play with. If you can use an engine stand with the cylinders vertical (engine 90° rotated), this will help keep the oil in the holes and not on your new head gasket. Oil pan, drain it. Then pull it off to clean it out. Reseal with quality sealant. Cooling passages - you’d probably be better off hitting any passages you can with a high pressure washer before starting any real work on the rebuild side of things. Just running water once the work is done won’t move anything. If it’s looking really nasty, getting a rod or a screw driver in there to remove scale can be effective. Ensure you get this crud out. When putting everything back together, clean all mating surfaces then wipe with methylated spirits or some alcohol wipe that completely evaporates without leaving a residue. Then apply your goo or gaskets etc and torque to spec. After about six months of continuous driving, it should develop an oil leak if you’ve done things right (joke! It should last longer than this!). EA82s always leak oil! On that note, they usually leak from the cam box where the sealant is the only barrier between the engine internal environment and the rest of the world. I hated this seal! Best method I found was to clean as described above, apply silicone to fill the channel and the edges of the mating surface. Then sit the cam box on the sealant and leave it to harden a bit before torquing the cam box down properly. And the VERY BEST method I found for EA82 oil leaks was to EJ it. The only EAs I tinker with now are EA81 units 😎 Edited September 29 by el_freddo More info Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted September 29 Author Share Posted September 29 The factory retorque procedure seems like a massive pain. Torque once using 3-step torque increments, reassemble and install the engine, get it to operating temp and let cool. Then loosen the intake manifold bolts and take off the cam carriers (may as well remove the intake manifold and pull the engine again), in the same torque order loosen the head bolt 60°, oil the threads between the washer and the head, torque to spec. Repeat on every bolt using the head bolt sequence 5 times. Then retorque one final time without backing off the bolts. Reassemble. I have no issue doing this to prolong the life of the head gaskets but I does seem like a PITA. Link to comment Share on other sites More sharing options...
el_freddo Posted September 30 Share Posted September 30 19 hours ago, SuspiciousPizza said: but it does seem like a PITA. EA82 lyfe! Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 2 Author Share Posted October 2 So I've been spending the past few nights after work cleaning up my deck surfaces and head bolt holes. I ran a thread chaser down all the head bolt holes and they all cleaned up great, however some of the gunk it scraped off the threads is now at the bottom of the holes. I don't want to use compressed air as I worry some of the holes go into the water jacket and I don't want to blow the gunk into the water jacket. Any tips and tricks here? I thought about using a wood screw to auger the gunk out or using some safety wire as a pick to get the gunk out. I used a small amount of engine oil to help the thread chaser and the gunk is sticking to the oil. Obviously brake clean would help get the oil out but I still worry about the brake clean blowing the gunk into the water jacket. :] Link to comment Share on other sites More sharing options...
el_freddo Posted October 3 Share Posted October 3 I don’t recall the EA82 having head bolt holes that go into water jackets. I you have it on an engine stand turn the holes to be cleaned upside down and let gravity do its work. You might only need to agitate it with a piece of wire. Then run the thread chaser down each hole again. Or so it on the bench by “whacking” the deck into a soft surface like a newspaper or towel on the bench. Anything that doesn’t come out shouldn’t be a problem. Link to comment Share on other sites More sharing options...
88SubGL Posted October 3 Share Posted October 3 You could try using a shop-vac. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 3 Author Share Posted October 3 34 minutes ago, 88SubGL said: You could try using a shop-vac I did, even with an adapter and a smaller hose, it helped but there's still gunk at the bottom of the holes. I'm going to try tipping the engine so the cylinders are vertical (and get myself bathed in coolant and oil), using a piece of wire as a pick to dig the gunk out and use a shop vac to help pull the gunk out. I know I'm making it more complicated than it needs to be, but I'd rather think it through rather than rush through. Link to comment Share on other sites More sharing options...
88SubGL Posted October 4 Share Posted October 4 If you’re going to flip the engine, shoot carb cleaner in the holes. It should wash it right out. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 8 Author Share Posted October 8 I have another question regarding oiling the head bolts. After doing some reading online, specifically for rebuilding EJ's, some people really stress oiling the underside of the washers (knew that) as well as the underside of the bolt heads. Doing this makes sense but the FSM doesn't mention doing that. So is it okay to only oil the threads and the underside of the washers? Or should I also oil the underside of the bolt heads? Also some people really stress using a high-pressure assembly lube rather than engine oil. The FSM specifically says "oil". I know it's not rocket science but with how rare parts are, I want to take my time and do it by the book and learn from other's experience rather than learn the hard (and expensive) way. :] Link to comment Share on other sites More sharing options...
el_freddo Posted October 9 Share Posted October 9 Do under the bolt head too. Engine oil will suffice. Link to comment Share on other sites More sharing options...
moosens Posted October 9 Share Posted October 9 Maybe i missed it but have you gotten an engine stand and flushed those head bolt holes? That’s going to be key. Same with bolt threads. Don’t sweat it all. Designs like these cam towers are reasons I have closed my chapter or EA82s but hey its your special engine so i understand your commitment. But to a lot of is older folks its just an EA82 and just do tour best, don’t go nuts with retotqueing the cam tower and etc etc but i am NOT a mechanic. Good luck. 1 Link to comment Share on other sites More sharing options...
moosens Posted October 9 Share Posted October 9 Wow my phone typos yeeehaaa Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 9 Author Share Posted October 9 (edited) Sounds good. I actually installed the heads last night but I think I'm going to undo the head bolts and redo it. The front upper corner head bolts on either side went in a little crunchy and my gut is telling me to redo it. Those two head bolts were extremely caked in... Something. A brownish white powder that looked like instant 3-in-1 coffee. I had the heads cleaned but those bolt holes had some grit left in them. I missed seeing it until those bolts went in crunchy and I inspected the holes. All the bolts were cleaned and the threads were chased and blown clean. When I redo the heads then I'll make sure to oil under the bolt heads and washers. Shouldn't take too long, just undo the bolts, clean the bolt two bolt holes, re-clean all the threads, and torque to spec. Should I let the heads sit torqued for a day before retorque? :] Edited October 9 by SuspiciousPizza Link to comment Share on other sites More sharing options...
el_freddo Posted October 10 Share Posted October 10 Ooh, part of me says it’s not a good idea to back them off and go again on those head gaskets. The other part of me says go for it, they’ve not seen a heat cycle yet. Worst case scenario you pop a HG prematurely. It an EA82 and not too complicated at the end of the day - “just” your time and some money. Your call on replacing the HGs if you choose to back them off and inspect those bolts. Do a search looking for a post by General Disorder about doing this exact thing with reusing head gaskets. I can’t remember what he recommended. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 10 Author Share Posted October 10 I'll just scrap the HG's and go out to my engine rebuilder to grab an extra set I had given them. Those are OEM gaskets anyways. 1 Link to comment Share on other sites More sharing options...
bushytails Posted October 19 Share Posted October 19 The crusty bolts are the ones that go into coolant passages. I wouldn't remove just two bolts. If you absolutely have to remove two bolts, untorque the whole head star-pattern in increments, remove and do whatever on the two bolts, and then re-torque all per specs. I use grease on the washers and heads (doesn't matter what kind of grease; axle is fine), then dip the threads in engine oil and wipe them off on a shop towel to remove excess. Someone told me a story of cracking a block with hydraulic pressure from installing dripping bolts and then torquing them, so I make sure it's not enough to be drippy. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 20 Author Share Posted October 20 Just thought I'd note something I learned. When you're installing the cam towers with the cams installed, you must first put on the rockers. The issue with the rockers is that you must use a lubricant to stick the rockers to the HLA's. If the lubricant you use is too thin, it will run down and could get on the sealing surface between the head and the cam tower. This will cause oil leaks since the RTV won't bind to the head. Rather than using an assembly lube, try using an assembly grease. Something very tacky with the viscosity of Vaseline or thicker. This will allow you to stick the rockers on without the worry of lube running onto a sealing surface. Once the cam tower is on, then you can use a normal assembly lube on the cam lobes and rockers. I still have to start up my engine and then do the retorque. I'll post back here if I learn anything when doing the retorque. :] Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 24 Author Share Posted October 24 Engine's in, most of the small bits and bobs are done. Not out of the woods yet. Tonight I was using the test connector trick to run my fuel pump. I wanted to prime the system and check my fuel lines for leaks before I add a hot running engine to the equation. When I was priming the system, I noticed the injector was firing. Is this normal? I knew when you have all 3 test connectors (SPFI engine) connected, it ran the fuel pump. However I don't know if the injector firing at the same time is normal or not. Additionally I pulled the codes while I was at it and I only got code 5. I believe I remember reading somewhere that this is one of those codes that means nothing and goes away when the engine fires up. It's not mentioned in the FSM. Any ideas on what specifically this code means? Is it just an indication of what "mode" the ECU is in? Like it's saying "this is an SPFI engine with a manual transmission". Thanks :] Link to comment Share on other sites More sharing options...
el_freddo Posted October 24 Share Posted October 24 The only “code” you should have is the one that states what market it was sold in. Eg here in Australia we have seven short flashes from memory. In my experience without starting the engine you shouldn’t have any codes to begin with. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted October 24 Author Share Posted October 24 I did some more digging and it's apparently just an indication of what transmission and emissions system the ECU is set up for. It's a non-trouble code. :] Link to comment Share on other sites More sharing options...
scoobydube Posted 6 hours ago Share Posted 6 hours ago My money is on the bearings on the inside of the engine, at both crankshaft, and piston rods, are rusted up so that you would have to tear the crankcase completely apart and replace them. Then the steel piston rings are probably also rusted in place and did not help the cylinder walls any. Long story short, you are wasting your time with an engine that has water condensing inside the crankcase, due to the changes in weather, regardless of whether it was under a hood or not. Link to comment Share on other sites More sharing options...
