Captain Ford Posted Wednesday at 04:03 PM Share Posted Wednesday at 04:03 PM I have a 99 Subaru Impreza Outback Sport Wagon with a 2.2 engine in it. It's got single header exhaust y pipe. When I'm going up a steady highway incline in 5th I begin to lose power. Even flooring it doesn't help very much. It doesn't happen in other gears. Even in 3rd on pretty steep hills but only in 5th on gradual hills. I'll be going like 75-80 and it will drop to about 65. Can someone help me out with this? Also is an EJ22 from a 2000 easily transferable over to the 99? Is it a straight swap? This current one in the 99 has been nothing but problematic for me. The guy I bought it from said its also not the original engine. But I have a good EJ22 from a 2000 that I wrecked that's at 107,000 miles and it was a fantastic engine. Link to comment Share on other sites More sharing options...
moosens Posted Wednesday at 09:02 PM Share Posted Wednesday at 09:02 PM My first thought is yes you’ve got from I think 1998-2001 plus or minus Not sure about doing a full swap but going to the two cam vs using the quad cam was an option many folks took up back when. Link to comment Share on other sites More sharing options...
brus brother Posted Thursday at 10:58 PM Share Posted Thursday at 10:58 PM So is there no deteriorating catalytic converter potentially contributing to clogged exhaust? Saw it on a Ford van years ago. Ran it loud and proud to diagnose a clogged cat. Link to comment Share on other sites More sharing options...
el_freddo Posted Saturday at 03:18 AM Share Posted Saturday at 03:18 AM ^ That was my thought too. As this issue gets progressively worse you’ll start losing power in other gears too. Link to comment Share on other sites More sharing options...
nvu Posted yesterday at 03:29 AM Share Posted yesterday at 03:29 AM I vaguely recall sohc single port EJ22 is an oddball thing somewhere around 97 when they went from phase 1 to phase 2. Are the valve covers on the heads the old school ones that have "16 VALVES" imprinted on them? \ If it's an 99 ecu, it's probably not really meant for those heads, probably why performance is poor. Good and bad is ecu is fairly simple and doesn't care which block is in there. Swap in the 2000 block, it's what the 99' ecu wants over all. Or if your state emissions doesn't care, drop in an 97-98 ecu and it might fix everything; if the current block has good compression and no mechanical issues. Link to comment Share on other sites More sharing options...
el_freddo Posted 2 hours ago Share Posted 2 hours ago The ecu doesn’t care about block or heads - it just wants the sensor data to tell the injectors what to do. Mix these up and you’ll have issues. Cam timing on the lobes *might* cause an issue but I have my doubts about that too. Swapping the block will not achieve anything. If swapping stuff, swapping heads for the correct units (if they’re not the right ones) will make things easier to diagnose. Issue with trying this out is that the intake manifold is specific to the phase one or phase 2 - so they can’t be interchanged which typically means it’s difficult to mix a phase 1 head and intake with phase 2 engine management. Link to comment Share on other sites More sharing options...
