April 23Apr 23 With the driving I've been doing lately, I've been considering switching to a full-time 4wd with locking center diff. I've been doing a LOT (sometimes 50 miles/day, 5 days a week) of gravel and dirt roads, too loose for 2wd, too solid for 4wd. I've been searching the forums for information about these transmissions, and the posts I've found mostly seem to be from people who have never seen one, as most of the information is directly contradictory... so I'm hoping to get some solid answers.What I want: 5spd full-time 4wd with locking center diff, 1.59:1 low range, 3.9:1 final, widest 1st-5th ratio possible. I'm in the US.Some posts say only the RX had full-time with locking center diff, some say also the XT6, while others say any ea82 turbo might have one. How to identify them is utterly unclear, either from looking at the transmission or at the interior of the vehicle, with no one apparently ever having actually seen one or otherwise giving a useful description. Some posts say they only came with 3.7 final, others say half of them are 3.9. Most say they have a poor (1.19, 1.2, etc) low range, but some say the 1.59 is a direct swap, some day it's not, some say you need au-only gears, and one even says 4spd parts fit, while I'm rather sure they do not. Some posts say that if you get a 3.7 you can swap the 3.9 pinion from an EJ box in, others say you can't, while some say you need XT(6?) parts. Some say it's a mechanical shifter, others say it's electric. el_freddo has a post saying nothing swaps without welding, but his posts are specific to a dual-range EJ tranny that's not available in the US, while I'd be using EA82 parts. Some posts say I'd need three transmissions, an RX, an XT6, and a non-turbo dual range.My current 5spd dual-range is in need of a rebuild (multiple bad bearings, input shaft wobbles an eighth inch, something clunks like a rod knock when in neutral, 5th->R lockout sometimes requires going all the way to the left then back to get to 4th, selector sometimes jams, synchros aren't the greatest, leaks from every single seal top and bottom and back and front...), so I wouldn't feel bad using it as a parts donor for the low range gears.I've tried doing a couple searches, and couldn't find anything available that looked like a full-time box. But, I don't know. car-part.com lists the full-time separately and says there's two available, but I think it's just lumping all ea82 transmissions together.So... What parts do I actually need? How do I identify them, either looking at the transmission or at the car it's in? Are they even available at all? Edited April 23Apr 23 by bushytails
April 23Apr 23 I'm not here to answer your questions, because I don't have the answers. I know you're in for quite a bit of searching and just as much work, but I can offer some help potentially finding parts.I know for certain my parts guy has a fulltime 4WD Turbo wagon. Problem is that I'm 99% sure it's a 4 speed auto. But the next time I'm over there (probably early June) I can take a look at all the cars he has and see what's available. He's trying to get rid of the parts and would like to know the parts are actually being used.Good luck though, if you can source everything it'd be a trick piece of kit!:]
April 23Apr 23 Author Definitely don't want an auto. lol. 5spd dual range for sure...I'm at the point where the more forum posts I read, the less I know, due to conflicting information...
April 23Apr 23 What you could do is look for options package pamphlets on eBay or the like. They may provide some insight as to what was offered from the factory. Could also get some RX and XT informational pamphlets. Just an idea.
April 24Apr 24 G’day @bushytailsThe L series AWD locking centre diff gearbox came in the RXII coupe, some XT4s and JDM GT wagons. I’m unsure about the XT6 - we didn’t get them here, infact all of these models except the XT4 were personal imports.How to tell them visually apart from the single range PT4wd gearbox with the vacuum actuator to engage the rear drive:this PT4wd single range gearbox’s lever to engage the rear drive is arm above the pivot point.The AWD locking centre diff gearbox is the opposite - the arm is below the pivot point for the locking centre diff engagement. I believe the dual range version will have the rods passing through the rear housing like the DR PT4wd gearbox.The AWD gearbox comes in single and dual range. Pick the one you want as it’s not easy for you to swap it to dual range without another dual range AWD gearbox (EA or EJ).The 3.9 ratio is out there from what I’ve heard, it’s hard to find. Mine was a 3.7 ratio.All of these dual range AWD boxes are 1.19:1 low range. The 1.59:1 transfers in without any issues, it’s a direct swap - need a donor NA dual range PT4wd gearbox.The EJ AWD gearbox pinion shafts are too short. I heard of a bloke that modified two of them to make one pinion shaft for the L AWD locking centre diff gearbox to get 4.44:1 diff ratio - to do this with the good L series low range requires the crown wheel to be shaved to clear the low range selector ring and gearset. I have not seen pics or videos of this done (the double EJ pinion shaft to make one L series AWD pinion shaft).From my understanding, L series PT4wd gearbox internals do not swap over to the AWD version, other than the low range. Everything will physically fit but it’ll become a part time box that requires the part time rear housing as well.My gearbox is made of EJ parts (drive gears and front cases) and the L series AWD bits for the locking centre diff and 1.59:1 low range.Ultimately if you’re on dirt that’s somewhat loose, you want to lock your centre diff, especially if EJ’d as it’s very easy to be spinning the front wheels faster than the rear, over working the centre diff that will lead to its destruction. You could be better off sticking with the PT4wd dual range box, the AWD is only worth it on solid surfaces.^ PT4wd in the foreground, AWD in the background, you can see the locking lever on the side here with the pivot point above the arm.I don’t have any better pics than the above sorry.I believe the dual range AWD gearbox is fitted with the same rod looking setup in the background of the gearbox as the PT4wd gearbox. My dual range AWD gearbox is built from a single range box originally, so my rear housing lacks the rods that I believe pass through the rear housing for the low range dedents/position retainer setup.Make sure you get the vacuum actuator and it works, plus the matching vacuum switch solenoids too, or have access to them. The single range PT4wd gearbox units work fine with the AWD box ;)I hope this helps. Edited April 24Apr 24 by el_freddo Embedding image
Sunday at 12:15 PM5 days 19 hours ago, bushytails said:I found a pic of a ft dr... it has both a vacuum pod cable and a manual lever.That’s the one!
Sunday at 05:34 PM5 days Author The harder part might be finding more than just a pic of one... and then figuring out how to get 3.9...
Monday at 05:48 AM4 days Finding one is the challenge - and one without a shagged centre diff. Finding a 3.9 is the unicorn. Hence why my box was put together with a modified pinion shaft for 4.111:1 diff ratio. From memory a 27 tooth speedo drive pulls the speedo back in perfectly with 27 inch diameter tyres. Again, from memory this came from an early Liberty gearbox - a gen 1 series 1. Need to find a suitable locking AWD gearbox first…
Monday at 05:56 AM4 days Author A couple forum posts I read said the XT6 came with a single-range locking center diff box with 3.9, and if you can find one of those too, you can make a dual-range 3.9 box, and have a spare center diff. I wonder if you even need an RX box or if you can mix-and-match a single-range full-time with a part-time dual-range front half...
Monday at 07:12 AM4 days You need to study the pinion shaft setup as this is the key to a conversion like that. If the PT4wd gearbox has a pinion shaft that floats on the pinion shaft and is independent of it, then they’re interchangeable. I haven’t fully investigated this but I believe the PT4wd’s pinion shaft is press fitted with the lower gearset. This is why you can use an EJ gearbox to make a dual range AWD locking centre diff gearbox that mates directly to the EJ engine (like I did). The nasty way to make a single range AWD LCD gearbox dual range is to find an RX turbo PT4wd gearbox with the same gear ratios, pinch the upper gearsets with the dual range setup and fit it with the lower gearset from the AWD LCD gearbox. ^ insert potential gear whining followed by potential early retirement of one of those gearsets. But you’d have a dual range LCD AWD gearbox..!
Monday at 10:28 PM4 days I've played with these, swapped gearing, diffs, etc. many many times over the decades (I've posted a lot of it here, search for my posts. Although most of the photos are probably gone). I have a little information in the Retrofitting FAQ. Here's a "quick" overview.RX is the ONLY EA-series transmission with dual range and FT4WD. It is also the only one in the US Market. I have heard of an EJ series dual range and FT4WD (with locking, not AWD) overseas, but I'm really not sure. Also would create it's own headaches with an EA engine (I assume that is what you're running just from context)RX has 3.7 axle ratios, 1.19 low range and .871 5th gearNon-RX EA82t FT4WD ('87.5+) cars are single range, 3.7 and .871XT6 has 3.9 axles, no low range and .780 5th.PT4WD D/R 5 speeds are 3.9 axle gears, 1.59 low and .780 5th (I believe '85-'87 turbo PT4WD cars are the same, but I'm not positive).14 hours ago, bushytails said:A couple forum posts I read said the XT6 came with a single-range locking center diff box with 3.9, and if you can find one of those too, you can make a dual-range 3.9 box, and have a spare center diff. I wonder if you even need an RX box or if you can mix-and-match a single-range full-time with a part-time dual-range front half...Might be possible, but the lower transmission gearshaft is different between part-time and full-time 4WD (FT is 2 piece with a pinion gear running inside of the transmission output shaft, PT has the pinion gear one and the same with the output shaft.The the low range gearset is part of the input shaft. You can swap gear ratios, but you have to start with a dual range input shaft and case.So without actually having an RX transmission to start with, you'd be using the input shaft from a PT4WD DR and the output shaft from the XT6. Since the drive gears for 1st, 2nd and reverse are part of the input shaft, you'd have to use the PT4WD driven gears on the FT4WD output shaft. I wouldn't bet that that would be interchangeable, but maybe.The center diff housing from the XT6 will not have provision for the low range linkage. Not a huge hurtle, but something that has to be addressed nonetheless.IMO, if the gravel is loose enough that you're spinning a front tire in FWD, than it's loose enough to run 4WD. I had an '86 wagon that was stock except the EJ22 and rear discs, I used 4WD when the ground was damp otherwise it would just spin away everything. Also, keep in mind, when the center diff is unlocked on a FT4WD, you have zero traction devices. If you hit the throttle hard in a turn, you will still spin up the front tire just like you would in FWD. I was so disappointed with the RX box in my Loyale. Even that tired non-turbo EJ22 could smoke the inside front tire coming out of a turn on dry pavement, and I was running 215/45r17x8+48s with High Performance All Seasons and EJ knuckles for better Akermann angle and camber.On my '88 XT6, I dropped phase 1 EJ internals into the XT6 front case halves. Better gearing (4.111 axle gears, but .738 5th, so lower rpm on the highway), and the center LSD is light years better than the open FT4WD.I had started combining all of this to make a dual range with 4.444 axle ratios, 1.59 low range, EJ AWD center diff, and a clutch-type front LSD, but that particular front LSD does not clear the low range set. I ended up scrapping the whole project. The front LSD might find it's way into the split-case 6 speed destined for my H6 Baja project, though....Experiment if you like, but I think you'll be very sad with the results, especially considering the amount of work to get there. It'd be so much easier to EJ swap, then you have the torque where you don't need the low range, and viscous center diff.
Tuesday at 03:43 AM3 days Author I have an EJ22 right now. I briefly had an EJ25, but got sold a bad block (was told it was perfect; instead rod knocked like a jackhammer) and had to pull it the next day, will probably rebuild it and try again at some point. I have an OBX for the front and a TORQ Locker for the rear.Don't need low range? I wish I could get 2:1 or better - my 1.59:1 low range isn't low enough!I am so sick of constantly switching in and out of 4wd, or needing more traction but then having to deal with binding, or it getting stuck in 4wd and needing to do the dance to get it out, or tearing up a loose driveway while making sharp turns, or wanting to put it in 4wd just for less slip up a hill but don't because I know it will then bind on a corner at the top of the hill, etc etc etc... I've been wanting AWD for a couple years now. Now that my dual range is getting worn out to the point I have to rebuild or replace it soon, trying to figure out what it would take.I'm not worried about the lack of a linkage. I was already thinking a second vacuum pod and another switch would be a really shiny solution. Pushbutton low range!But, I have no idea what the gear interchangeability is.I don't want to go to 4.44 unless I get a super high 5th at the same time... I'm already at 3200rpm on the highway and burning $50+ of gas every day...Found https://www.ultimatesubaru.org/forum/topic/95638-411-awd-dual-range-in-legacy/ , which shows you can put EJ lower shaft with EA dual range upper shaft... except theirs promptly exploded. But the explosion may have been due to ring gear bolts backing out. But that thread also has tons of wrong information, like saying the EJ AWD and the RX FT4WD pinion shafts are the same length, which I've seen pictures showing is very much not the case. Sigh. Edited Tuesday at 03:44 AM3 days by bushytails
Tuesday at 11:50 AM3 days 13 hours ago, Numbchux said:when the center diff is unlocked on a FT4WD, you have zero traction devices. If you hit the throttle hard in a turn, you will still spin up the front tire just like you would in FWD. I was so disappointed with the RX box in my Loyale.That sucks Numbchux! I haven’t experienced that as I fitted mine with a front OBX LSD. On one or two occasions I managed to spin the front wheels on a loose road when taking off hard. EJ22 powered. I don’t drive like a maniac so my gearbox lasts a long time ;) 8 hours ago, bushytails said:Don't need low range? I wish I could get 2:1 or better - my 1.59:1 low range isn't low enough!Me too. Maybe one day I’ll do the 4.44:1 diff ratio and lower 5th ratio… 8 hours ago, bushytails said:which shows you can put EJ lower shaft with EA dual range upper shaft... except theirs promptly explodedLike Lego! But mismatch gear ratios will do that very quickly! Even gearsets of the same ratio will do weird things and end up popping at some stage due to different wear over the life of the gearsets being matched together.
9 hours ago9 hr On 4/27/2026 at 10:43 PM, bushytails said:I am so sick of constantly switching in and out of 4wd, or needing more traction but then having to deal with binding, or it getting stuck in 4wd and needing to do the dance to get it out, or tearing up a loose driveway while making sharp turns, or wanting to put it in 4wd just for less slip up a hill but don't because I know it will then bind on a corner at the top of the hill, etc etc etc... FT4WD will be the same. Locked will bind up, unlocked will spin.Front LSD helps, but center LSD is better.If you've already got an EJ engine, get an EJ dual range. Swap your low range gears into it. Better traction, better clutch, better availability.You have a .780 5th gear. Many EJs have a .738 5th gear. So you could switch to a 4.111 or even 4.444 pretty easily and keep your highway gears.
1 hour ago1 hr Author EJ dual ranges do not exist in the US, and I want the ability to lock the center. Edited 1 hour ago1 hr by bushytails
49 minutes ago49 min Author I have owned EJ AWD subarus, with open center diffs, and know from experience they have much less issues on these same roads. Now, there are plenty of other differences - tires, suspension, vehicle weight, etc - but it makes sense that if you only put half the torque to the front axle, you'll spin it a lot less.
