August 25, 200421 yr Does anyone have a 88 gl 10 with an automatic tranny. i have the chance to get a gl 10 for $300 with only minor problems. if anyone has had good or bad luck with automatic trannys or if the turbos have problems? please post anything that you know
August 25, 200421 yr The 3AT tranny isnt the most impressive thing that Subaru put in their cars. They usually go out around 120K if I remember right. The Turbo's rarely have problems, If anything they can cause problems with the cooling system. Try to feel all the coolant hoses for weakness and such. I've only had manual transmissions so I don't know too much about the auto ones. Someone should clarify for you though. Good luck,
August 25, 200421 yr I have had 2 88 GL-10 turbos.. one was an auto.. Someone around seattle is still rollin that tranny in a different car I believe My 87 GL-10 turbo was also an auto.. that tranny is probably still working as well.. Last time I heard it was. I didn't want it.. did the 5 speed swap
August 25, 200421 yr I had two turbo GL-10's from that year. One I purchased new and kept for for over 13 years. Neither of them had a problem with the automatic tranny. The biggest problem I know of is with the alternator and head gaskets.
August 25, 200421 yr i have a 88 full time 4wd a/t turbo gl-10 wagon w/ 90,000mi , make sure you run a 2row radiator , mine also had the air struts ,but i had to replace the fronts , mine runs great and shifts good , k-n filter , acell coil, ngk plugs, 2in pipe all the way back
