TotallyCorupt Posted November 10, 2004 Share Posted November 10, 2004 i was talking to my buddy who is pretty suby swavy and he said that its alot of work to do the swap from an EA82 to the EA82 turbo motor. he said you have to do the hole wiring harness and all that stuff, well i dont know if he said all that but...i just want to check this out and make sure that its is. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
calebz Posted November 10, 2004 Share Posted November 10, 2004 Motor, exhaust, cross member, wiring harnes.. Bunch of other little random crap. Not a lot of fun Quote Link to comment Share on other sites More sharing options...
TotallyCorupt Posted November 10, 2004 Author Share Posted November 10, 2004 why the cross member? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 10, 2004 Share Posted November 10, 2004 so the downpipe coming off of the turbo can clear it Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted November 10, 2004 Share Posted November 10, 2004 well here's the list..i HIGHLY suggest not doing it... Motor COMPLETE engine and dash harness + cpu...don't even try it with a digi gauge turbo fuel pump PS hardlines( yes the power steering lines are different between turbo and NA) cross member and alot of asprin!!! Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted November 10, 2004 Share Posted November 10, 2004 It is far easier to find a car that is already turbo'd, there are plenty of EA82T cars out there. Quote Link to comment Share on other sites More sharing options...
oddcomp Posted November 10, 2004 Share Posted November 10, 2004 well as far as electronics go.. you could go the do it yersel route and use a meagquirt for the fuel and ignition but you still have teh crossmembers and such to argue with Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 12, 2004 Share Posted November 12, 2004 think the wiring is pretty easy, you just have it as a stand alone part. all you have to do is power it, ground it, have it controll a relay for the fuel pump, and hookup the trigger wires on the coil, and connect a wire from the computer to the starter solenoid wire. then the rest plugs in like stock to the engine/intake. thats on the flapper system, i think the hotwiere would be easier, as you wouldnt have to run the trigger wire to the coil. dash and everything plugs in using your stock wiring from the car, even if its an ea81. i love it! it all fits! Quote Link to comment Share on other sites More sharing options...
TotallyCorupt Posted November 13, 2004 Author Share Posted November 13, 2004 thanks for the info guys i know now that i am not going to be doing this swap, and ill just look for a EA82T. Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted November 13, 2004 Share Posted November 13, 2004 another thing to consider is that you have to pass DEQ also (damn vultures again) Quote Link to comment Share on other sites More sharing options...
AKIRA Posted November 14, 2004 Share Posted November 14, 2004 a legacy conversion would be more worthwile Quote Link to comment Share on other sites More sharing options...
