FUEL ECONOMY///Are The Carbs Diff. Between 2 And 4 Wh Dr.
Often times the wiring harness on the carb is different too. My 87 used to be a 3 wire system harness. I bought a 2WD carb for it many years ago cause the original one crapped out. It as a 4 wire system so I had to adapt it to be 3 wire.
So ya the carbs are different. I got awful mileage with the 4 wire carb converted to 3 wire so careful what you do.
I later changed to a weber. More power AND better mileage!
