A mate removed the distributor and how It wont start
Bro
Hi all, Because of a dodgy compressor install on the dissy my mate removed the distributor to remove the compressor, replaced it, and now we can't get the thing running again. We obviously rooted the timing...
What do we do ???
81 Wagon EA81 Engine / Carb
Thanks
Remove the disty, remove the #1 sparkplug, put your finger in the hole then turn the engine by hand. When you feel the air being pushed out of the cylinder then you have it at TDC. Line up the rotor just to the right of the plug wire on the disty cap and when you set it in it should be lined up.
Your da man :grin: Quick reply, Quick fix, Excellent :banana: Thanks ......... On the road again :clap:
