What would you do?
I have two turbo 88 subaru wagons but need to sell one. Heres the lineup:
Blue
1988
5spd
full time 4wd with lsd
medium rust
160k on car
blown head
digidash
ok brakes
ok struts
pwr sunroof
pimp interior
good tires
hub caps
turbo
cold ac
grey
1988
5spd
minimal rust
push button 4wd no lsd
minimal rust
220k on car
good heads
analog dash
brand new brakes
brand new struts
no sunroof
stinky interior
bad tires
no hubcaps
turbo
no ac
Im thinking about pulling all the drivetrain and bad motor out of the blue car.....rebuilding the motor and slapping it all in the gray car. Then take everything from the grey car, put it in the blue car, and sell the blue car for 800-1000 bucks. This would give me the grey car with full time 4wd and lsd with a motor that should last for a while?? What would you do??
How long does it typically take to pull the motor, trans, and diff off one of these wagons?
I would keep both. lol
Fix up the blue one, use the parts from the Gery one to fix BLue one. After all, sounds liek blue is a GL-10....bettAr car overall. Use new stuff from gery to fix blue. Put the 'ok' stuff on the grey...either keep it for parts, daily driver, or fix it up to be reliable and sell it.
just put the grey heads on the blue engine
save the blue
make grey the donor
is the lsd viscous?
Make one the best of both, sell the 2nd. To swap things over like you said takes me about 1 full day. Island time. :drunk:
No need cause I got a set of heads already for the blue one....and a complete reseal gasket set.
make grey the donor
I cant bring myself to it. Its in great shape and could do someone as a real good driver. There are no issues with the grey car except 2nd gear rinds a little....and it hesitates a little. Nothing major though.
is the lsd viscous?
Not sure??? How do I tell?? It says "full time 4wd" on the door??? Havent looked at the diff sticker yet??
Thats what I want to do. Just cant make up my mind on which one to keep. The blue GL10 would be the keeper hands down, but the rust scares me. Thats the only bad part about the GL10. It will have brand new heads and complete reseal by the weekend. But I can pull all of the engine/tranny/full time lsd and put it on the grey 88gl too (which has less rust)???
