alternator!!!!
hi i really need help... im stuck in northern ontario and my alternator just broke up!!!! Is there an alternative or i must find a subaru one!!!!!!
I got a 4wd loyale 93.
Or with which models it could be replace by or anything that could fit...
as my battery indicates 12 v when i test it, my ultimate test was when i let the lights on, the engine goes down and finally die. but if i shut the lights before it dies, the engine keep running and dies finally. i gess its the alternator. If someone got any clue, pls let me know. The battery can hold a charge..
Thx very much...
Any ea82 alternator will work.
From 85-94 wagons sedans and hatch.
I think and 84-86 brat alt will work too. it just needs to be a internally regulator alternator.
I guess you could use a 80-84 ea81 alternator too if you had a external voltage regulator to hook up to it.
What went out on your old one? is it not charging, or is it charging at 18+ volts?
Try a search on alternator swaps. I was just talking with Snowman and he was talking about doing anuograde toa Chevy (I believe) alternator that kicks out more amperage, but I don't know the details. I seem to recall a few discussions about this modification about a year ago. If you're stuck in a spot where Subaru parts aren't generally available, this may work for you.
:) I like to just fix whats wrong with them. in my jeep its usually just dirty contacts. go ahead and take it apart and fix it.
Yep.. clicky.
