84 brat blower motor question
are ea81 blowers the same as ea82's ? and the location of the blower motor on a 84 ea81 brat
can't say whether they are the same but the blower moter should be behind the glove box
stan
changed the blower motor ,but still no blower ,in fact no power going to the blower , i checked all fuses ,
i had i problem like that on my 84 wagon got tired of trying to find the problem so i just ran a new power wire and used a toggle switch to turn my fan on and off
did you check the switch? I had a similar issue with my very first ea81 wagon, and they (service place, before I did my own work) ran a new wire to feed the fan, but the stock switch still worked....
already tested for power at the switch , i just ran a wire from the fuse box to the greem/ white wire
One thing to be aware of is some heater circuits use the speed switch to complete the ground portion of the circuit. I'm not sure how this one is designed but it may be like that. If that is so then there should be power at the motor but it won't work until the ground portion is completed.
fan speed controls and air control buttons can cause these problems sometimes. but i'm not familiar with brats or EA81's.
