April 22, 200521 yr I was bummed out because the junkyards around here I usually go to for the odd part for my Loyale had recently crushed their Subes. On the way home I drop by this new U-Pull place and lo-and-behold a 1988 GL SPFI. And here's what I found on 'em: KYB GR-2 341066 HJ06 is the model apparently. Does this one not look too bad? I only took one because I'm no expert (was a mother***** to take off) Theres some weird red dust in the middle where the rod meets the lower half and I can see some more at the very top inside the top dust boot. The lower dust boot is loose and can move up and down which I hope isn't that big of an issue. I for myself can't see any oil leakage. Also, these are probably 2WD struts as the car was a manual 2WD. I have a 4WD Loyale, so they should fit, right?. So should I get the other one? This cost me $30.
April 22, 200521 yr I thought you had found the fronts one, I don't think they make the rears anymore tho but I'm not really sure.
April 22, 200521 yr Author I'd just like to know if it's worth it before I tear off the ones on my car. The rear end is unbelievable squeaky even at really low speeds, but I don't want to put on something that doesnt fit or isnt much better.
April 22, 200521 yr They'll fit. IIRC, the 2wd springs and such are shorter. Overall, if in good condition, they may very well yeild decent results
April 22, 200521 yr They are the correct pt#. Some internet searching found that the number is still good. They are still available and run around $38.00 ea. This doesn't include the springs or attachment hardware. Odd thing is that the XT6 uses a different pt#.
April 22, 200521 yr Odd thing is that the XT6 uses a different pt#. If you look at an EA82 parts book you'll see there's about half a dozen different rear coilovers.
April 23, 200520 yr Author the red dust is the internal bump stop rotting. Sooo, is this bad? Seriously, does it affect the strut performance majorly?
April 23, 200520 yr Sooo, is this bad? Seriously, does it affect the strut performance majorly? if it bothers you just buy new bumpstops. you have to compress the spring and unbolt the top and you will see it.
April 23, 200520 yr get some newer impreza/legacy bumpstops and cut them in half and use them front and rear. The stock ones are...well, not cheap.
