is the turbo oil pump different from the na version?
I need a oil pump for my '92 2.2 turbo and i'm wondering if it's the same as a non turbo version.
thanks
thanks
no, it has xtra outlets for the oil cooler.
I did not see a difference in the pictures, I don't remember the oil cooler line coming off of the oil pump but haven't had one off in about 6 months.
But the part # is different and I believe that have a different oil pressure rating.
I was wondering why the different part number, anyway, I need one for a turbo, I guess I gotta bite the bullet.
Wouldn't that make it a different part?
That's not right.
The oil cooler does not go into the oil pump.
The pump is different on the turbo legacy. It outputs a higher pressure due to the fact it has oil squirters in the block.
<<The oil cooler does not go into the oil pump.
The pump is different on the turbo legacy. It outputs a higher pressure due to the fact it has oil squirters in the block.>>
yup, thats right. i just looked at the 2.2T i'm building, the water pump has the xtra lines not the oil pump. like 777 said, just a higher output.
