XSNRG Posted April 23, 2005 Share Posted April 23, 2005 I need a oil pump for my '92 2.2 turbo and i'm wondering if it's the same as a non turbo version. thanks Quote Link to comment Share on other sites More sharing options...
svxpert Posted April 23, 2005 Share Posted April 23, 2005 I need a oil pump for my '92 2.2 turbo and i'm wondering if it's the same as a non turbo version.thanks no, it has xtra outlets for the oil cooler. Quote Link to comment Share on other sites More sharing options...
richierich Posted April 23, 2005 Share Posted April 23, 2005 I did not see a difference in the pictures, I don't remember the oil cooler line coming off of the oil pump but haven't had one off in about 6 months. But the part # is different and I believe that have a different oil pressure rating. Quote Link to comment Share on other sites More sharing options...
XSNRG Posted April 24, 2005 Author Share Posted April 24, 2005 I was wondering why the different part number, anyway, I need one for a turbo, I guess I gotta bite the bullet. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted April 24, 2005 Share Posted April 24, 2005 no, it has xtra outlets for the oil cooler. Wouldn't that make it a different part? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted April 25, 2005 Share Posted April 25, 2005 no, it has xtra outlets for the oil cooler. That's not right. The oil cooler does not go into the oil pump. The pump is different on the turbo legacy. It outputs a higher pressure due to the fact it has oil squirters in the block. Quote Link to comment Share on other sites More sharing options...
svxpert Posted April 25, 2005 Share Posted April 25, 2005 <<The oil cooler does not go into the oil pump. The pump is different on the turbo legacy. It outputs a higher pressure due to the fact it has oil squirters in the block.>> yup, thats right. i just looked at the 2.2T i'm building, the water pump has the xtra lines not the oil pump. like 777 said, just a higher output. Quote Link to comment Share on other sites More sharing options...
