T-Belt Tensioner
Howdy all - how difficult is it to compress the tensioner by hand then slide the retainer pin in?
Other methods welcome also.....
Ryan 97 OBW
I use a vise, compress it slowly. A large C clamp might work as well
Very. It also has to be compressed at a slow, steady rate. Use a regular bench vise, it works well.
Regards,
Adnan
Very important to compress it VERY slowly. IIRC, the manual says 2 minutes or something of that magnitude.
Haynes gives a warning about the later version, but if you're working on the '97 OBW in your sig line, I don't remember seeing any warning.
Since my vise was one of many tools that didn't make the trip cross country last year, I got by using a jack and my Jeep. Now that I think about it, it took about 2 minutes for it to compress all by itself. It moved so slowly that I couldn't actually see it. Make sure the holes are lined up.
...and when your finished with that the next step is to post your question only once... :lol:
A large C clamp works just as well, and is a lot cheaper and easier to carry than a vise. . .
