August 18, 200520 yr i can't remember which is which. but they are the opposite of "normal injectors"
August 18, 200520 yr 2.7ohms isnt considering low impedance last time I checked. I used to have a pair of Performance Low Impedance Injectors for the Acura and they were like less than 1ohm
August 18, 200520 yr Author Ok... are the injectors Peak and Hold? Or Saturated? Peak and Hold is supposed to be High Impedance Saturated is supposed to be Low Impedance
August 18, 200520 yr I thought they were LOW, thats why they need the resistors, to control the current. I thought low was around 3 ohms or less and high were around 12-16 ohms. I dont have my book here to check but the 2.7 number sounds right. Gary
August 18, 200520 yr my my my .. sounds like someone is doing the covert megasquirt conversion... i could suggest you just run the injectors to the megasquirt and the cut the main lead to the resistor block and wire it to a relay that gets tripped from the + side of the coil wiring since its a switched + .... but then again what would i know..
August 18, 200520 yr ps low ohms = high amp loads .. high ohms = low amps loads stock suby injectors + stock resistor block = just fine in my setup
August 18, 200520 yr Author Actually, i'm trying to determine if the DSM injectors I have fitted (which are high impedance) can be driven by the stock system without damage. I will not be upgrading to Megasquirt yet... but I have an SAFC to help tune for the larger injectors.
August 19, 200520 yr measure the ohms across the terminals of the old injectors and the resistance of the dsm units then measure the resistance of the old resistors with the dropping resistor in line compare the 2 and see if you can run them with the resistor block or with out
August 19, 200520 yr Author Ok... So I measured the resistance. 2.5-2.7 ohms on the stock ones... 11.4-11.8 on the DSM's. This was out of car. I guess I will be running the stockers to begin with. Please outline how to test with the "resistor block"... would this upp the OHM's of the factory injectors... thus meaning if I removed it and the stock injectors and ran with the DSM's it would be fine?
August 19, 200520 yr disconnect the plug at the resistor block it should be the center pin thats the main power feed to the resistor block one probe of the ohm meter on the main power wire and the other from one of the resistor output wires actually now that i think about it look in a chiltons book or something like that it has the test measurments for the resistor block technically as far as i know if the combined resistance of your old injectors + the resistor block = to or pretty close to the dsm injectors.. then the dsm's should work minus the resistor block
August 20, 200520 yr Ok... are the injectors Peak and Hold? Or Saturated? Peak and Hold is supposed to be High Impedance Saturated is supposed to be Low Impedance They are Peak and Hold 2.5s. Here is an old data sheet I posted up of my RX turbo injectors being cleaned at RC Engineering. On another unrelated note, you said you have (or will be using) an SAFC. I've asked a question many times to folks who have used the SAFC on older Subarus but never got a reply. My questions are: 1) What is your Sensor Number set at on your SAFC?, 2) What is your Sensor Calc set at on your SAFC? Please answer those if you can so I won't be frustrated for another year. Thanks!
