September 27, 200520 yr Shady... on the front top strut extensions....where is the L and R located exactly... do you have a pic on how they are supposed to be oriented? Thanks
September 27, 200520 yr Mine are stamped right on the top of them like this (circled in red since it's so small and kinda hard to see in the picture):
September 28, 200520 yr Author The EA81 should be shipped out by this week. I talked to the shop master aka Albie and he was picking up the last of the metal and bolts. I will notify when shipped. JM AA Just checking in again to see how the ea81 kits are doing. :cool:
September 28, 200520 yr HMMMM? The EA81 should be shipped out by this week. I talked to the shop master aka Albie and he was picking up the last of the metal and bolts. I will notify when shipped. JM AA
September 28, 200520 yr TA-DA! Couple questions...2 rear shock mounts ...................check 2 triangular mushtash bar blocks....check 2 engine blocks...........................check 2 frount strut blocks....................check 2 other blocks.....? 1. Are the transmission mount lowering blocks? 2. Are there blocks for the other rear mounts on the mustash (crossmember) bar? 3. Are there blocks to go betwine the transverse link (control arm) and leading rod or betwine the leading rod mount and the body? 4. Are there center bearing mount lowering blocks? if not , Is the Differential angle important to U-joint life? Thanks Dave
September 28, 200520 yr Author 1. Are the transmission mount lowering blocks? There the triangular pieces. 2. Are there blocks for the other rear mounts on the mustash (crossmember) bar? Only the mounts for the rear mustache bar. 3. Are there blocks to go betwine the transverse link (control arm) and leading rod or betwine the leading rod mount and the body? Engine cradle blocks are the big squares, and the front strut extensions. 4. Are there center bearing mount lowering blocks? if not , Is the Differential angle important to U-joint life? There are center bearing mount lowering blocks. Thanks Dave
September 28, 200520 yr Couple questions...2 rear shock mounts ...................check 2 triangular mushtash bar blocks....check 2 engine blocks...........................check 2 frount strut blocks....................check 2 other blocks.....? 1. Are the transmission mount lowering blocks? 2. Are there blocks for the other rear mounts on the mustash (crossmember) bar? 3. Are there blocks to go betwine the transverse link (control arm) and leading rod or betwine the leading rod mount and the body? 4. Are there center bearing mount lowering blocks? if not , Is the Differential angle important to U-joint life? Thanks Dave Maybe this will answer your question... the control arms are attached to the engine crossmember, so yes, they are lowered too
September 28, 200520 yr ok... mine sooo do not that the letters on them, but! I noticed that they are kinda triangularly shaped, but more kinda arrowish... Can anyone give me an idea which way goes towards the front of the car? I'mm make sure that they are that direction and if the camber still looks bad, I'll swap them. The camber on one side right now looks good, but the other side is pretty bad........ \-----| .......Maybe someone can put arrows on DrKrazy's pic of "to the front of car" and "engine is over there" Thanks guys... Hey shady whats the word on my 5th wheels... and what about the shifter protector blocks? be creative, there's nothing too hard... also, about the pitch-stopper, maybe try a jack & wood block on the oil pan to tilt the whole thing back a bit, that's a trick someone suggested for changing the clutch (to align engine and tranny easier), I did it when I did my clutch, and didn't take the jack off until I had the pitch stopper back on. it worked fine! Chux my engine fan almost touches the skid plate in front and the rad... in fact when I accelerate hard, you can hear the fan eating its self...... If I pitch it back, wont it always be hitting... my pitch rod is about 2" too short now it seems
September 28, 200520 yr Chux my engine fan almost touches the skid plate in front and the rad... in fact when I accelerate hard, you can hear the fan eating its self...... If I pitch it back, wont it always be hitting... my pitch rod is about 2" too short now it seems my engine fan was touching my skidplate...but the skidplate didn't reach the x-member. maybe that's part of your problem, my skidplate was like 2" too short. AND I took off the mechanical fan... and if the fan is hitting the skidplate, than pitching it back will to the opposite, it'll give you more space...you're driving it without the pitch stopper attached? just giv 'er a try, pull of the skidplate, tilt the engine back some, if you really have to jack hard to get it to reach, don't go there, but if it seems to tilt relatively easy, go for it.
September 29, 200520 yr ok... mine sooo do not that the letters on them, but! I noticed that they are kinda triangularly shaped, but more kinda arrowish... Can anyone give me an idea which way goes towards the front of the car? I'mm make sure that they are that direction and if the camber still looks bad, I'll swap them. The camber on one side right now looks good, but the other side is pretty bad........ \-----| .......Maybe someone can put arrows on DrKrazy's pic of "to the front of car" and "engine is over there"Thanks guys... Hey shady whats the word on my 5th wheels... and what about the shifter protector blocks? Chux my engine fan almost touches the skid plate in front and the rad... in fact when I accelerate hard, you can hear the fan eating its self...... If I pitch it back, wont it always be hitting... my pitch rod is about 2" too short now it seems Does this offset diagram look close? Right and Left sides should be mirror images. right?
September 29, 200520 yr Author Bingo on the diagram. Hey King I will get that wheel out Friday, sorry about the delay. I can get tranny guard protectors for anyone who wants them, we just usually don't install them, because we have never had a problem with the shifter link being smashed. Your call pm or email me if you want em. JM
September 30, 200520 yr can anyone make me a pic of the top and how its supposed to face? That other pic is very helpful firstsubaruglwagon thanks! Now I just need the top so I can get these things in correctly.
September 30, 200520 yr can anyone make me a pic of the top and how its supposed to face? That other pic is very helpful firstsubaruglwagon thanks! Now I just need the top so I can get these things in correctly. Well This is a guess I haven't recieved my kit yet so I could be wrong. However they should look something like this... or maybe..... wich ever puts the botom bolt holes closer toward the engine or wheel well
September 30, 200520 yr HEY Just got my Kit today! Everything was packed nice and tight. Im going to reread the directions and all the posts here in the hopes i can lower the problems I may incounter durring instalation. I have just one sugestion for the kit thus far. Instead of just R and L stamped on the strut blocks maybe stamp DR for drivers side and PAS for passenger side. This may aliviate some instaltion issues, because Right and Left are really relative to where one is standing or sitting. (Learned that from Albert and Costello) Just a sugestion, not a complaint Thanks, Dave
September 30, 200520 yr left / right on a vehicle is always relavtive to you sitting in the drivers seat
September 30, 200520 yr left / right on a vehicle is always relavtive to you sitting in the drivers seat yes thats the way it shoud be :-p
October 1, 200520 yr Ok I'm putting on the lift as I write this. First of many questions. Should I dial the shocks and struts back down to the lowest setting now?
October 1, 200520 yr Ok I'm putting on the lift as I write this.First of many questions. Should I dial the shocks and struts back down to the lowest setting now? YES! unless you like replaceing axles, I made this mistake and burned through quite a few in just a couple months
October 1, 200520 yr Must be work on your lift day...I too started lifting "Project Cheap" today. Didn't have awhole lot of time before it got dark, but probably put in about 4 somewhat lazy hours (no air tools). The rear is totally done, front strut mounts done (Mine were marked correctly, and only seemed to want to go in one way). So far everything has been fairly straight forward and bolted up. Only problem I have ran into is that the tranny blocks are extremely hard to get lined up. So far have only gotten 2 bolts into one, 3rd isn't lining up..and took me at least an hour and half just to get that far on the tranny mounts alone.. That's where I stopped for the night, hopefully with a fresh start tomorrow I can get it finished fairly quickly. Will be some pics in the "Project Cheap" thread.
October 1, 200520 yr Hey I just finished the back too. It was surprisingly easy:banana: Sounds like i am going to have some problems tomarrow:lol: Air tools help,but, one tool that is an absolute must is a Radio!
October 1, 200520 yr YES! unless you like replaceing axles, I made this mistake and burned through quite a few in just a couple months Ah , I better jump on that then. thanks I might buy that 3"differential lowering adapter from SRJ too.
October 1, 200520 yr Ah , I better jump on that then. thanks I might buy that 3"differential lowering adapter from SRJ too. Not necessary if you're staying at 4"....but I rub alot, and more lift > fender cutting! So I'll be adjusting my strut extensions back down the extra inch (is this even an option anymore?) and dropping the diff 2".
October 2, 200520 yr Got mine completely finished today, looks like I might have been wrong and have an ever so slight camber issue on the front. Really not bad though, maybe the few miles I drove it didn't get it to settle enough. Everything went beautifully after I disconnect the torsion bars. Only have a few problems... 1.My steering wheel doesn't line up at all anymore, cocked like 30-45 degrees when the wheels are straight? I tried putting it on a few different ways and always ended up with the same thing...am I missing something or is that just how it's going to be? 2.Pitch Stopper is just too short now 3.No more skid plate at all....oil pump/filter is right there for a smacking (gotta fix that) 4.No more mechanical fan, will have to pick up an EA81 Electric to run in it's place. Will be more pictures in the "Project Cheap" thread after I go take a really long shower and have at least one beer...then I will post them. Got 3 thumbs up just driving it around my neighborhood for a few minutes.
