September 26, 200520 yr Finally, I have one... We solded the harness up tonight, and we got it to idle. Next step is tomorrow night, at the shop we will instll the IAT sensor, and tune it on the dyno. HUGE thanks to http://www.diyautotune.com/ for the hardware and soldering services!
September 26, 200520 yr Author its NOT plug any play....yet. Plug and play kits will be avalible for Leone's soon....exclusively thru WJM Rallye Sport. This is the experimental/prototype unit. WJM
September 26, 200520 yr its NOT plug any play....yet. Plug and play kits will be avalible for Leone's soon....exclusively thru WJM Rallye Sport. This is the experimental/prototype unit. WJM any idea of what the pricing will be?? that will be hot
September 26, 200520 yr Author about.....alot. Lets just say...more than $400, and less than $800. My kits might include a wideband setup for autotune, so that will adda bout $200 onto the cost.
September 26, 200520 yr Whenever I bring my kits to market, I'll be sure to sharply undercut WJM here! Good job on getting it running, now get it tuned!
September 26, 200520 yr about.....alot. Lets just say...more than $400, and less than $800. My kits might include a wideband setup for autotune, so that will adda bout $200 onto the cost. will that be including the ms box or is that just the adaptor kit?
September 26, 200520 yr Author It will be the complete kit....remove stock ECU, plug up the MS, tune and have fun. Whenever I bring my kits to market, I'll be sure to sharply undercut WJM here! Good job on getting it running, now get it tuned! ha...ha...ha.... at this rate i dont think WJM Rallye Sport is going to get off the ground for quite a while...all Leones world wide might rust away. LOL
October 6, 200520 yr Author Tonight we played some more with it....it is currently idling like OE...which means steady ~1000 RPM idle...no missing. Just smooth idle. Next...more idle and crank-start tuning...then off to the dyno to tune.
October 6, 200520 yr That is so sweet. If I ever build up an EA82T, this is going to be high on my list.
October 9, 200520 yr Author Ok, so we are up to 113/133 as compared to stock 106/129.... still lots more to do. and YES...the MS is in, and working perfectly.
October 9, 200520 yr Author well, 116hp/140tq are the semi-final numbers. thats 10hp and 6tq increase. Off boost power is a ton better...and butt dyno on the street says its really around 20hp/15tq increase. A lot left to do.....throttle enrichment during driving is way off....its got a weird timing stumble between 2000 and 3000...and MS-2 doesnt feature knock system monitoring or control at all...that's got me stopped on tuning. the 12x12 table....lacks....fine resolution. I could not get the AFR's smooth...but they are better...no more pig rich....mostly 10.5~11.5 in boost. tried to get 14.7 everywhere else...but it smooths from 14.7 to 12 when comming into boost...then from 12 to the sweet spot range for boost. Timing is...set...to...alot. I need knock system stuff damnit!
October 9, 200520 yr where are my fuel maps bish?!?!?!? lol certainly worth the hassle of making it work huh pay attention and you should notice the turbo coming in a little to alot sooner especially if you add a a little extra fuel in the 90-100 kpa range you want a copy of my timing maps? to see if that helps ? they are pretty much tuned by ear and feel and engine temp but seem to work fine for me for now until i get rich and can play on a dyno maybe i can con some dyno place up in pdx in giving me a break for it being such a one off setup lol
February 13, 200620 yr Maybe one of you guys running MS2 could write-up what is needed to install it on a ea82t? Like all the connections and hickups you've obviously solved. Would be great for future users of MS2 thanks in advance
February 28, 200620 yr Author the stock Disty...and usisng it to disty the spark. Or...was...since there's an EJ22E going in now..
February 28, 200620 yr the stock Disty...and usisng it to disty the spark. Or...was...since there's an EJ22E going in now.. Thanks, that was my plan for now.
March 1, 200620 yr dylan, are you installing MS on your EA82T? you're going to have MS and EDIS? have you started yet?
March 1, 200620 yr dylan, are you installing MS on your EA82T? you're going to have MS and EDIS? have you started yet? Gary, I have a spare MSnS'e that I built a couple years ago. One is on my Neon but I haven't mounted or wired the spare on the wagon yet. I don't know if I'm going EDIS or distributor. As I have the 86 distributor I don't know how I'm going to address the constant spark signal. I'm still pretty new to subaru but I believe the 86 turbo distributor still has mechanical advance and not computer controlled (separate knock box). I could pin the advance so the signal out of the distributor is always at TDC. Getting the EDIS parts doesn't bother me but then I still need to machine and mount the crank wheel. Actually this weekend, there is the big MegaSquirt get together in Virginia Beach with the designers and folks from all over the country. We are meeting up at a dyno shop Saturday and Sunday. There should be details here: http://www.msefi.com/viewtopic.php?p=104803&highlight=#104803
March 1, 200620 yr sweet, nice. i'd like to do this to the XT Turbo once it's up and running. is this set-up reliable? or constant maintenance?
