4x4moose Posted November 2, 2005 Share Posted November 2, 2005 i was wondering how much sea foam i could put in my oil. couple of days ago i put about 4 oz in, it seemed to help with the lift noise for like an hour of driving, then the noise started up again. then today i put 5-6 oz in and didn't do a thing but i didn't drive all that long, like 10 minutes or so. i also have a bunch of mmo in my oil, is there any problem with mixing with the two? Link to comment Share on other sites More sharing options...
RichLo65 Posted November 2, 2005 Share Posted November 2, 2005 read the back of the bottle.... it depends on how big your oil pan is, it give a oz per quart diagram thing. Link to comment Share on other sites More sharing options...
Subarian Posted November 2, 2005 Share Posted November 2, 2005 Also realize that seafoam and marvels both are thinner viscocity than your engine oil, so you need to take both into account when determining how much you're diluting your oil. I personally wouldn't go more than 1 quart in a 4-quart engine. If that much doesn't do it, more won't help. Link to comment Share on other sites More sharing options...
4x4moose Posted November 2, 2005 Author Share Posted November 2, 2005 yeah the can says 1.5 oz per quart, i guessed that there was about four quarts or so. i was told that mmo made the oil thiker do to some chemical reation. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted November 2, 2005 Share Posted November 2, 2005 I saw remove the old oil, mmo and seafoam. Drain it all and replace it with 1qt of MMO and top it off with 10w30. Forget the seafoam in the oil. -Brian Link to comment Share on other sites More sharing options...
4x4moose Posted November 2, 2005 Author Share Posted November 2, 2005 that was my next step, change the oil, evan the ive have changed the oil like 3 times and have only owned it for like 2.5 or 3 months i think. like every 1000 miles or so. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted November 2, 2005 Share Posted November 2, 2005 Well, i wouldnt be running with oil that has both MMO and Seafoam for too long. If the oil is too thin it wont stick where it needs to, and wont do what its gotta do. After an oil change on my old legacy, i developed a real bad case of the ticks. I had to drain alittle of the oil, replace with MMO to help thin it out and that still didnt work. So i took it on the freeway and maintained 80mph in 4th gear (rougly 7000rpm) and that did the trick. -Brian Link to comment Share on other sites More sharing options...
WJM Posted November 2, 2005 Share Posted November 2, 2005 So i took it on the freeway and maintained 80mph in 4th gear (rougly 7000rpm) and that did the trick. -Brian y3333s! I need to do that with my outback I guess.....lol Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted November 2, 2005 Share Posted November 2, 2005 I did it out of frustration. Was pissed and that ticking was driving me CRAZY! So i tried to kill the engine... and what do you know, i fixed it! Not sure if EA82s will act the same way. Mine wont even reach 7k -Brian Link to comment Share on other sites More sharing options...
WJM Posted November 2, 2005 Share Posted November 2, 2005 no no no...the EJ25D in my outback. Link to comment Share on other sites More sharing options...
DrKrazy Posted November 2, 2005 Share Posted November 2, 2005 Haha well after I resealed the oil pump in "Project Cheap" it was still ticking like crazy...so I basically did the same thing (was half pissed off too) except not driving it. Wrapped it up to 6-7k and held it there for a few minutes until it went away. Sometimes a good wrapping up is what it takes to get those lifters pumped up I think....or I was just beating the heck out of the engine and it decided to quit out of coincidence. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted November 2, 2005 Share Posted November 2, 2005 Maybe just gotta get that oil hot enough to work its way everywhere. Thats what i was trying to do on my test drive. A straight 6 mile stretch of freeway did the trick -Brian Link to comment Share on other sites More sharing options...
idosubaru Posted November 3, 2005 Share Posted November 3, 2005 ATF works good too (if it's the HLA's sticking). i've used 2 out of 5 quarts of ATF in an XT6 i had years ago. didn't keep it in there long, maybe a week and a couple hundred miles at most. Link to comment Share on other sites More sharing options...
idosubaru Posted November 3, 2005 Share Posted November 3, 2005 if you used any ultra grey sealant on anything like the cam carriers or oil pump housing, that can cause tapping as well. it'll get sucked up and caught in an oil port and retstrict oil flow to the HLA's. that's why anaerobic sealant should be used. someone on xt6.net sealed an oil pump or cam carrier with ultragrey and had tapping that wouldn't go away. he eventually tore it back down and found the ultragrey plugged into an oil port. posted pictures of it as well....may have posted on a different group though, i can't remember but i know he's on xt6.net sometimes. Link to comment Share on other sites More sharing options...
MorganM Posted November 3, 2005 Share Posted November 3, 2005 read the can... Link to comment Share on other sites More sharing options...
