subiemech85 Posted November 23, 2005 Share Posted November 23, 2005 I need more clearance for the rear tires 195/60 R15 to fit without interference when loaded and I hit bumps, accelerate, or corner I only have about 1.5" from top of tire to bottom of wheel arch The question is should I lift it or swap on the rear adjustables form the '85 wagon :cool: lift costs money, but the adjustables I have. The real reason for the car is going through the snow Quote Link to comment Share on other sites More sharing options...
dmcdlrn Posted November 23, 2005 Share Posted November 23, 2005 hehe, you could do what I did... go to the parts store and pick up some of those rubber spring stiffeners and jamb them into the spings... picked me up like 2.5 to 3 inches all the way around. But, be more careful on those corners! Quote Link to comment Share on other sites More sharing options...
soobmater Posted November 23, 2005 Share Posted November 23, 2005 uh your i bet your axles love you! not so much the back one's, but the fronts! you could swap for the adjustables, and just lift it up a notch or two, that probably won't be to bad..but you might be best goin with a 3 inch lift.. Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted November 23, 2005 Share Posted November 23, 2005 Use 2WD sedan struts with your stock springs, should give you about an inch I believe. I think WJM has done it. Quote Link to comment Share on other sites More sharing options...
rallyruss Posted November 23, 2005 Share Posted November 23, 2005 I found that springs from the front of certian hondas will lift the rear nicely. I just happen to have a set lying around too. I now have adjustable coil overs in the rear and no longer use them. let me know if you are interested. there were some old threads around from when I first discovered this. Quote Link to comment Share on other sites More sharing options...
calebz Posted November 23, 2005 Share Posted November 23, 2005 Adjustable coilovers for the win. Keep stock height, just stiffen it up a little;) Quote Link to comment Share on other sites More sharing options...
omniman69 Posted November 23, 2005 Share Posted November 23, 2005 i installed 91 loyale strut assembly's onto my xt and it got me 2 inches lift, and also allowed me to sell my air system(wink) with all 3 struts(wink again), cheap. mike Quote Link to comment Share on other sites More sharing options...
