Seahag1978 Posted December 21, 2005 Share Posted December 21, 2005 When I start out in 1st gear, I get this repetitive noise that gets faster with speed. It makes the noise in 2nd gear too. In 3rd and 4th gears it's gone while I accelerate, but then it reappears randomly for a few seconds when I take my foot of the gas and coast while still in gear. When I coast while in 1st or 2nd it's constant. It doesn't sound metallic at all. It sounds dull, like tapping a drum with a broken skin with a drumstick. It doesn't matter whether I'm driving straight or turning. The car runs, shifts and drives great. Oh, it's a lot louder when it's really cold and quiets down a bit after driving a mile or 2. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 21, 2005 Share Posted December 21, 2005 Possbilty a CV joint. Do you feel any vibration or clunk in the car anywhere? -Brian Quote Link to comment Share on other sites More sharing options...
Seahag1978 Posted December 21, 2005 Author Share Posted December 21, 2005 Nope... it doesn't feel like a CV (I have had a few of those go I do notice a kinda buzzing... no, not really buzzing... kinda more like hissing under my foot while barely resting on the clutch. Quote Link to comment Share on other sites More sharing options...
beetreesubie Posted December 21, 2005 Share Posted December 21, 2005 is it in the motor if so my brat does same thing Quote Link to comment Share on other sites More sharing options...
75subie Posted December 21, 2005 Share Posted December 21, 2005 hopefully not a tranny problem:-\ Quote Link to comment Share on other sites More sharing options...
Seahag1978 Posted December 21, 2005 Author Share Posted December 21, 2005 It sounds like it's coming from the right side. I don't think it's coming from the tranny, I had a ring and pinion go once... that was the same noise regardless of the gears... that sounded like a baseball card stuck in the spokes of a bike then graduated until it sounded like a Subie rolling around in a cement truck. Quote Link to comment Share on other sites More sharing options...
beetreesubie Posted December 21, 2005 Share Posted December 21, 2005 well jon mine is sounds like its comin from the left front piston oil pump workin no leekin no burnin no water in it `jus makes noise Quote Link to comment Share on other sites More sharing options...
Huckersteve Posted December 21, 2005 Share Posted December 21, 2005 well jon mine is sounds like its comin from the left front piston oil pump workin no leekin no burnin no water in it `jus makes noise It couldn't be our loud sticky lifters could it? Mine just took a turn for the noisier.... Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted December 21, 2005 Share Posted December 21, 2005 I had a speed related noise from under the car, couldn't locate it for a long time. Turned out to be the driveshaft u-joints. Always worth a look-see:) . Just my 2 bucks Quote Link to comment Share on other sites More sharing options...
fud24682000 Posted December 22, 2005 Share Posted December 22, 2005 Converter rattle? Ray Mac Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 22, 2005 Share Posted December 22, 2005 I had a speed related noise from under the car, couldn't locate it for a long time. Turned out to be the driveshaft u-joints. Always worth a look-see:) . Just my 2 bucks First thing I thought of... Quote Link to comment Share on other sites More sharing options...
Seahag1978 Posted December 22, 2005 Author Share Posted December 22, 2005 How would we check the u-joints? Sounds like the most likely so far, since I haven't had the joy of experiencing that particular about-to-leave-you-stranded noise yet But would the noise go away under load? Quote Link to comment Share on other sites More sharing options...
Seahag1978 Posted January 10, 2006 Author Share Posted January 10, 2006 I kept driving it until it really made itself known. The noise was never a click but like a drum roll. We spoke to edrach regarding another matter and he suggested that it was probably the axle since they do some strange things. It was the axle, it felt ok when it came out, but it fixed the noise. Quote Link to comment Share on other sites More sharing options...
edrach Posted January 14, 2006 Share Posted January 14, 2006 The inner DOJ on the axles is the most mysterious in terms of the symptoms it can present. The CVJ is always more obvious since it clicks on turns pretty consistently. DOJ problems are less obvious and can be just a slight vibration under acceleration or so bad that you think the tranny is about to fall out of the car and any other drivetrain related symptom. And there doesn't seem to be any way to tell by looking or wiggling or any other tricks to diagnose the problem. Whenever there's a noise that is speed related, I think drivetrain, and the axles are always my first choice when a visual inspection of the drivetrain doesn't find an obvious culprit. With the multitude of rebuilders out there who don't actually replace a joint "if it looks okay" I've learned that even newly rebuilt axles are likely to fail within the first month or two of installation. The rub is trying to prove it to the supplier. Quote Link to comment Share on other sites More sharing options...
Hayne Posted January 15, 2006 Share Posted January 15, 2006 I read through this thread, so I know this hasn't been asked. What everyone else has said is viable. OK. I'm not trying to be funny or assanine. Does this car have any type of spring held hub cap? The reason I ask is, they can make a noise similar to what you describe when a spring gets weak. It goes with the speed of the wheel and can be anything from a click to a squeek to a grate. It doesn't necessarily do it all the time and can change with the temperature. I know this sounds stupid but our '90 Loyale had the small center caps and made a racket. Our daughters had dish hubcaps and made the same...but different racket. If it does have caps it would be worth eliminating. Things are seldom that simple though. Quote Link to comment Share on other sites More sharing options...
scrap487 Posted January 15, 2006 Share Posted January 15, 2006 i got the same thing going on right now... both ujoints on my rear driveshaft are toast and one cv in the rear is gone, there is so much play in the shaft its not even funny. Quote Link to comment Share on other sites More sharing options...
Seahag1978 Posted January 15, 2006 Author Share Posted January 15, 2006 With the multitude of rebuilders out there who don't actually replace a joint "if it looks okay" I've learned that even newly rebuilt axles are likely to fail within the first month or two of installation. The rub is trying to prove it to the supplier. I have found this to be true on at least 3 occasions. I am so lucky to have found a parts man that knows this and he takes them back for full credit and an apology and free stuff!! He says the same of rebuilt carbs and he won't even sell them. He says only 1 in 5 are good so I gave him roobuilders addy, Kerry is GOOD! Fortunately, I bought axles that had 3k on them and any defects would have surfaced by now... they should be fine for 100k with my driving habits Quote Link to comment Share on other sites More sharing options...
