Info LSD
New here, great site. Ive read a bit about lsd's here but I was wondering what my options are for any kind of lsd or vlsd for my 1986 gl wagon. Is there anything from a newer sube that would bolt right up to my setup? (91 legacy??) any info and two cents would be great, thanks.
A stock LSD will bolt up from a newer Subaru IF you swapped out transmissions as well. Otherwise, you'll have to swap some of the internals and such from a different LSD into an open diff. Its not hard at all though. I'll see if I can get a link to the swap. You might wanna look for 87-89 Full Time 4WD Rx's at the junkyards they have a 3.7 LSd in them. Also, some 89 xt6's have been said to have a 3.9 LSd which WOULD be a bolt in swap for your wagon, but good luck I don't think I have seen a single one for sale since I've been here.
if i remember correctly, and i may not, the only legacy to get a 3.90 VLSD was the 1991 legacy turbo. now, other cars do have the VLSD (WRX, SVX, some legacys, and some imprezas) but that ratio is 4.11, and i dont know if you can swap the ring and pinion gears from a 4.11 VLSD into our 3.90 diff's.
~Josh~
Yes 91 Legacy SS has the VLSD 3.9 rear end on it. IT is a clutch pack based limited slip. A 3.7 LSD off a GL-10 and the 3.9 LSD off a RX and XT6 are spring based limited slip.
People on the board said not to use VLSD for offroading. I love mine. IT goes anywhere. And it works a lil better than the spring type when cornering because it makes more wheel spin to get it to lock up.
RX has 3.7 ;)
