how can i tell if spfi or mpfi
i have an 88 gl and was wondering how to tell if i have the single port or a few of them. rookie question, i know. but thats what this board is all about. learning.thanks
yes i agree. na ea82 mpfi xts are pleantyfull
if its mpfi it says multi point fuel injection and has two aluminum runner s on each side, instead of just one tube.
if its spfi it has a tube, and yours could even be a leftover carb, which has a wierd almost oval shaped aircleaner on top.
FYI, in '85 they actually made a few GL-10 sedans and wagons with MPFI.
I have one, it's a '85 GL-10 2WD wagon with MPFI and no turbo. It's the only one I've seen other than XT's.
the 85s they are talking about are ea82s. there were never na ea81s with mpfi.
mpfi na only gomes on ea82s
The intake plentum should say SPFI or MPFI in large letters ontop.
Either that, or look at your engine block. If you have metal tubes leading to Injectors, 2 on each head... then you have MPFI. If there are no injectors in the heads its a SPFI or Carb.
-Brian
my intake plenum on my 88 gl wagon just says "Subaru F.I." it's single port but like i said, it doesn't say spfi or mpfi on the plenum. is everyone else's the same, or is my car just that unique?
