February 19, 200620 yr Yup, '89 RX, 120K, everything works, took off the body kit before the extreme rally test (anybody want to buy a complete body kit?), passed with some coolant and oil leeks and some fresh underbody body damage... once I pull the tranny and diff you can have it for cheep. ac works good. cd player, Gen III turbo heads, good turbo, dual core radiator...
February 19, 200620 yr Why not offer a trade for the parts that you want and save some labor and time?
February 19, 200620 yr Author Eh its just a toy, when it breaks it will get parted, unless somebody really wants it sans diff and trans...
February 19, 200620 yr Eh its just a toy, when it breaks it will get parted, unless somebody really wants it sans diff and trans... You have a running turbo '89 RX, but want to pull the trans and differential to put into another vehicle? What trans does it have - d/r or 4eat? 3.7 or 3.9? What vehicle are they going into?
February 19, 200620 yr it should have a fulltime 4wd 5 speed D/R in it. I dont think Rx's came with autos. At least the ones I've looked at in person
February 19, 200620 yr The car has a Dual Range AWD Gearbox with locking center diff. ALso, the rear has a limited slip 3.9 That tranny and diff combo was only offered in the RX. -Brian
February 19, 200620 yr '89 rx should be 5spd d/r ft4wd 3.7 could be auto how's the body, rust?? does it have HEAT????
February 19, 200620 yr Author yup runs & drives like a raped ape, flies through the air pretty good too. D/R AWD 3.70 center diff lock, rear LSD, all the goodness of 10 forward gears. don't get me wrong the rx 3 door is a cool car, had one all rallied out, wrx IC and 3" straight pipe, full roll cage, tons of fun, but I've had it with the ea82T they are too much work too often, I I'll stay with my ej22's and ea81's thank you.
February 19, 200620 yr Author yup car has great heat, it's waay below zero here currently, rust, well a litle surface rust, if I wanted a 3 door this would get done up right trans and diff are going into my '91 legacy. first one on the block.
February 19, 200620 yr I WANT YOUR BODY!! Free Range" Eh its just a toy, when it breaks it will get parted, unless somebody really wants it sans diff and trans..." shall we make a deal? /begin hijack/ when the ambient temp was +4f, the "heater" sent out +4f air good thing I had my harbor freight 12v "heater" to warm one had at a time this was the last chance, from now on it's my '81 diesel wabbit pickup /end hijack/
February 19, 200620 yr not too shabby. At least it runs compared to when I first got my '89 and mine was also a 4EAT automatic. '89 was the only year you could get an automatic in an RX but it was the 4EAT, not the 3AT.
February 19, 200620 yr Yeah I have an 89 RX with 4at. It's great. I'm impressed with the Auto tranny. I had a 3at in my ea81...that was crap. But this tranny is nice. But I would like the FTAWD 5spd with center diff lock. That's a good car...too bad you don't like them.
February 19, 200620 yr Wow if it wasn't so trashed I would have given you a RX trans+diff plus a good chunk of change for it. I'm sure someone will pick it up if the rust isn't too bad though. Have fun with the swap, it is a nice drivetrain!
