gemery10 Posted March 2, 2006 Share Posted March 2, 2006 hey guys, Im in the process of putting in 32/36 dgv carb into ea 82. I only have one fuel line in that elbow. Is that normal? What happens to the return line already there for the hi carappy Quote Link to comment Share on other sites More sharing options...
mcbrat Posted March 2, 2006 Share Posted March 2, 2006 I usually pull the fuel fitting with the little return pipe off the hicrappy, and use it on the weber. Quote Link to comment Share on other sites More sharing options...
Bobby_boucher Posted March 2, 2006 Share Posted March 2, 2006 i just capped the return and everything seems to be fine. Quote Link to comment Share on other sites More sharing options...
Subarian Posted March 2, 2006 Share Posted March 2, 2006 I would plumb the return line. I originally had mine capped off, but pressure would build in the tank on hot days, and sometimes I would get leaks and other times I'd just have to live with a strong gas smell. There's a plug on the other side of the fuel inlet on the Weber. You can install a barbed fitting there for the return line. I used two elbows so that the barb is pointing to the back of the carb; that way the return line lies right next to the fuel line. Quote Link to comment Share on other sites More sharing options...
spanky_pete Posted March 2, 2006 Share Posted March 2, 2006 I usually pull the fuel fitting with the little return pipe off the hicrappy, and use it on the weber. This is what I'm planning on doing with mine. Quote Link to comment Share on other sites More sharing options...
gemery10 Posted March 2, 2006 Author Share Posted March 2, 2006 you guys rock. thanks heaps. Bottom line I can run with one line till summer or I get a round to it Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 3, 2006 Share Posted March 3, 2006 I have done that: http://www.ultimatesubaru.org/forum/showthread.php?t=53143 My Loyale have two return lines, so I did plug them between theirselves, and that way it works very fine. Quote Link to comment Share on other sites More sharing options...
