J A Blazer Posted March 12, 2006 Share Posted March 12, 2006 I recently acquired a 2000 Outback wagon with 6-disc in-dash CD changer. I have read the manual and can get the changer to accept a disc, but it then spits it back out. These are pre-recorded CDs, not MP3 or home-brew, and yes the label is up. Any ideas or tricks? TIA. Quote Link to comment Share on other sites More sharing options...
Suzam Posted March 12, 2006 Share Posted March 12, 2006 Does it spit it out on it's own without you touching any buttons? I remember hitting the #1 button thinking I was loading additional disks and was ejecting the disk in slot #1. Have you tried selecting an different slot? Try pushing say..#4, you should hear the mechanisum wind up the slot for you to insert the disk. Afterwards it winds back down and you can select another button/slot for another disk. Quote Link to comment Share on other sites More sharing options...
J A Blazer Posted March 12, 2006 Author Share Posted March 12, 2006 Yes, it spits it out on its own. And no different results regardless of which numbered slot I try. Quote Link to comment Share on other sites More sharing options...
xdeadhead Posted March 12, 2006 Share Posted March 12, 2006 maybe it's full already. (prev owner didnt remove their 6 discs) justa thought as that will prevent loading of any more discs) Quote Link to comment Share on other sites More sharing options...
Suzam Posted March 12, 2006 Share Posted March 12, 2006 maybe it's full already. (prev owner didnt remove their 6 discs) justa thought as that will prevent loading of any more discs) Assuming the LED indicators still work, they'd be on if a disk was present. Blazer: can you hear the motors running for the slots? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 13, 2006 Share Posted March 13, 2006 mine does the same thing and i can't figure it out. i'll replace it at some point, but would be awesome if there was a "fix". Quote Link to comment Share on other sites More sharing options...
JEGIII Posted March 13, 2006 Share Posted March 13, 2006 When the original CD player in mine did the same thing I was told it was the optical head was dirty or broken. Something about it not being able to read the disc as good or not. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 13, 2006 Share Posted March 13, 2006 When the original CD player in mine did the same thing I was told it was the optical head was dirty or broken. Something about it not being able to read the disc as good or not. was there a fix, what did you end up doing? sounds like a cleaning of some sort isn't a bad idae. i'm thinking blast it with the air compressor. Quote Link to comment Share on other sites More sharing options...
Rich in NEPA Posted March 13, 2006 Share Posted March 13, 2006 Could it possibly have something to do with your CD? Did you try inserting different ones? Shortly after I'd gotten my '00 Outback I purchased a music CD that had some sort of new copy-protection encoding. Every time I inserted it into the vehicle's CD player it would spin up and then immediately spit it out! All of the other discs I owned played fine. The problem was somehow related to the copy protection scheme on the CD itself, and evidently the player couldn't read it. I haven't tried any known copy-protected CDs, assuming they're still using that ridiculous concept on current CDs, in my subsequent '04 or my new '06 Outback 6-disc players. Cheers ... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 13, 2006 Share Posted March 13, 2006 i tried multiple CD's, but i'll try again. before and after i blow compressed air inside it. Quote Link to comment Share on other sites More sharing options...
JEGIII Posted March 13, 2006 Share Posted March 13, 2006 I got a 6-disc AM/FM cassette out of a WRX. They show up on e-bay pretty regular and much cheaper than new OEM. The consensus at the sound shops I went to, was it was cheaper to replace than repair. Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted March 13, 2006 Share Posted March 13, 2006 I paid $130 for a WRX am/fm/cass/6disc off eBay, shipped...worth every penny. (It's now in my GL-10) Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 14, 2006 Share Posted March 14, 2006 that's where i got mine too! so i tested it again last night. how does this thing work anyway, my CD player has never worked. turns out, i can't even insert a CD. when i push the CD or TAPE button nothing happens. When i push load nothing happens. Tape player works if i push the tape in. since mine has never worked, how does the Load and CD button work? Quote Link to comment Share on other sites More sharing options...
lmdew Posted February 25, 2011 Share Posted February 25, 2011 So did anyone ever get there 6 disk to work. It's been years since the last post. I picke up a 2001 unit out of the yard, $15. I can hear the disk changer trying to change when I first turn the key on, but it will not load disk or eject them if they are in there. Quote Link to comment Share on other sites More sharing options...
J A Blazer Posted February 25, 2011 Author Share Posted February 25, 2011 I started this thread. I gave up on my 6-disc changer years ago. Replaced it with an OE single-disc cd player I got off ebay. Has worked perfectly.l Quote Link to comment Share on other sites More sharing options...
lmdew Posted February 25, 2011 Share Posted February 25, 2011 Yes, I saw it was an old thread. I thought someone may have an update. Sounds like either they work or NOT and they are not worth fixing. Larry Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted February 25, 2011 Share Posted February 25, 2011 lmdew: Yes, either they work...or they don't. All of the controls are solid-state and a bad alternator or voltage spike will take out the whole unit. They aren't worth fixing. That said, the one in my GL-10 worked perfectly 'til I sold the car, and last year I picked one up for my wife's Baja-which is also working perfectly. (At least that one was plug-and-play, no messing with the wiring harness.) Gary: To load a disc, press CD, then press LOAD, then press the slot you want (the 1 through 6 buttons), then insert the CD. To eject, press CD, press the number of the disc you want to remove, then press EJECT. Pressing CD and then EJECT will eject the next CD in the queue, not necessarily the one you actually want to remove. Hope this helps. Andrew Quote Link to comment Share on other sites More sharing options...
Durania Posted February 25, 2011 Share Posted February 25, 2011 I've got a WRX 6 disc changer in my 95 Outback. 2 weeks ago the thing stopped reading CD's and wouldn't eject them. Sucks, I loved how the thing looked and was free. Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted February 25, 2011 Share Posted February 25, 2011 They still pop up on eBay for about a hundred bucks plus shipping. If I were to do it again, though, I'd probably get a single-disc out of an Outback - the one with CD/cassette/AM/FM and weatherband. Quote Link to comment Share on other sites More sharing options...
Durania Posted February 25, 2011 Share Posted February 25, 2011 They still pop up on eBay for about a hundred bucks plus shipping. If I were to do it again, though, I'd probably get a single-disc out of an Outback - the one with CD/cassette/AM/FM and weatherband. +1 Although, I quit fooling with ebay a long time ago. Found I can find Subaru parts better and cheaper on boards like this one and nasioc. Quote Link to comment Share on other sites More sharing options...
wrongturninwv Posted February 26, 2011 Share Posted February 26, 2011 Well here you go,maby this will help.I bought a McIntosh 6 cd player off Ebay that had the same problems. I got mine to work and read cds by cleaning the laser lens. My HD is the Pf-25201. 5 screws hold the top cover on. Before you remove top cover make sure you never turn radio upside down once cover is off. There are 2 pins that will fall out,my guess is these are shock pins so when you hit bumps the cds wont skip. Now the fun part,find the laser lens. I never saw one before so it took me some time. It looks like a small glass or plastic round eye. It sees the bottom of cd and thats how it reads it. And it is connected to an arm that slips under the cd when it plays. A clean Qtip and alcohol (not the kind you drink) will clean the dust off. Gary, dont shoot the air in there ! Lots of small springs inside ,you may make things worse. I bought a color coded Subaru wire adapter for hooking up aftermarket radios and pluged it into the back of mine and used a DC power supply box and could watck everything work inside the cd played. Its like an unbelivable robot. Do not stare at laser,can burn your eyes they say.Do not try to hook it up indors without an adapter.You will short it out. If your not sure of what your doing take it to a radio shop that you (trust). Type in online how to clean a lazer lens. Some sites have pics. Hope this helps. And Gary buddy, give some thought to that amp. I will can tell you by the end of the week what wires to use to get those front speakers going. Good luck ! Quote Link to comment Share on other sites More sharing options...
wrongturninwv Posted February 26, 2011 Share Posted February 26, 2011 Please make sure you put top of cd player back on before you test it, cover holds down those 2 shock pins I told you about. thanks Quote Link to comment Share on other sites More sharing options...
