March 29, 200620 yr So LUVMYRBAT's daughter has this '84 t-coupe. Yesterday, while driving around town, the tranny started making a whirring noise on decelleration. I took it for a quick test drive (and BTW, it hauls butt compared to the turbo Brat) and heard the same sound. Whenever you're on the decelleration, it has this loud whirring sound coming from the transmission. Acelleration and cruising it seems fine, no slippage, just the sound when you're off the gas. I have yet to crawl underneath it to see if there's a chance of something rubbing on it somewhere but its weird. Also, on decelleration, with the tranny in neutral, it makes the same noise but not as loud and the speed of it goes with the speed of the car. Any thoughts? Oh, tranny has been replaced before in this car. This is the replacement tranny LUVMYBRAT got from TurboXT a few months ago. No problems until this.
March 29, 200620 yr Sounds like the gear that drives the modulator perhaps.... pull the modulator and check the drive gear for wear. Front diff gear oil? GD
March 29, 200620 yr Fluid swapping is my guess as these are known for that. If so check the reduction gear for damage.
March 29, 200620 yr Author sweet, I also forgot to mention that he said it wasn't reading on the stick so he added like a quart and a half to it before he could read it on the stick. Fluid seemed to be all right in color but I'll drive it again and see if there is a fluid swappage between the front diff and the tranny. Anymore thoughts?
March 29, 200620 yr check the governor, could be apple cored. Might not be, but I've heard it's a common problem.
March 29, 200620 yr check the governor, could be apple cored. Might not be, but I've heard it's a common problem. Thats how mine went out. I swapped in a 5 speed dr tranny and couldn't be happier! This car is pretty quick with a proper transmission.
March 29, 200620 yr Author sweet! well since we have the extra parts laying around, might as well just do that then trying to stick a 5-speed in there for right now. Eventually, it'll hopefully get a NA d/r 5-speed;)
April 21, 200619 yr well I pulled out the govenor today on my day off hopin to see a bad apple core syndrom but not so:banghead: the govenor actually looked great very little if any signs of apple coring. good news for that but bad news overall, looks like a tranny swap is in order.
April 21, 200619 yr well I pulled out the govenor today on my day off hopin to see a bad apple core syndrom but not so:banghead: the govenor actually looked great very little if any signs of apple coring. good news for that but bad news overall, looks like a tranny swap is in order. If the govenor gear looks good, save it when you replace the tranny. Could be worth something to someone down the line.
