Escapegoat Posted April 9, 2006 Share Posted April 9, 2006 Im assuming its shocks, tell me otherwise if suspect something different Quote Link to comment Share on other sites More sharing options...
nipper Posted April 9, 2006 Share Posted April 9, 2006 first clean out your trunk or hatch area to make sure its nothing loose. Could be shocks, shot bushings, a bad exhaust pipe hanger, or that racoon you ran over last week nipper Quote Link to comment Share on other sites More sharing options...
frag Posted April 9, 2006 Share Posted April 9, 2006 first clean out your trunk or hatch area to make sure its nothing loose. Could be shocks, shot bushings, a bad exhaust pipe hanger, or that racoon you ran over last week nipper I thought a racoon went "squwash a quishy" :-\ Quote Link to comment Share on other sites More sharing options...
nipper Posted April 9, 2006 Share Posted April 9, 2006 I thought a racoon went "squwash a quishy" :-\ well if the bugger gets wound around the axle nipper Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted April 9, 2006 Share Posted April 9, 2006 The only thing worse than your own road kill is running over someone elses! Seems like you are thunkin' right...shock it probably is. Kevin Quote Link to comment Share on other sites More sharing options...
Skip Posted April 9, 2006 Share Posted April 9, 2006 If what ever car this is has a rear sway bar. Worn bushings in the links to the control arms can cause this noise Quote Link to comment Share on other sites More sharing options...
