ericem Posted April 21, 2006 Share Posted April 21, 2006 Ok today my car was ready. I go to try it out. SO first thing we do. Floor it and make tight turn no bind good! Then we floor it.. 6000rpms 6500rpms and im still in 1st GEAR!!! so the guy tells me its a governor but before i brought it it never did this. So i turn off the car turn it on and guess what the POWER LIGHT FLASHES!! ABS LIGHT WAS ON!! AND MY SPEEDO ISN"T SYNCED!! tell me did i get screwed. The guy told me he has to reprogram something. Is it possible something isnt connected. Or the guy swapped the tranny. ANY ADVICE. The guy charged $1500 with clutch packs and drive solenoid c, bearing(all four) and rear differential leak fixed. But it does shift when u dont floor it no problem. SO if i only go to 6400rpms it will shift fine. Well there working on it tommrow ill run a TCU test . Replys are much apppreciated! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 21, 2006 Share Posted April 21, 2006 Ok today my car was ready. I go to try it out. SO first thing we do. Floor it and make tight turn no bind good! Then we floor it.. 6000rpms 6500rpms and im still in 1st GEAR!!! so the guy tells me its a governor but before i brought it it never did this. So i turn off the car turn it on and guess what the POWER LIGHT FLASHES!! ABS LIGHT WAS ON!! AND MY SPEEDO ISN"T SYNCED!! tell me did i get screwed. The guy told me he has to reprogram something. Is it possible something isnt connected. Or the guy swapped the tranny. ANY ADVICE. The guy charged $1500 with clutch packs and drive solenoid c, bearing(all four) and rear differential leak fixed. But it does shift when u dont floor it no problem. SO if i only go to 6400rpms it will shift fine. Well there working on it tommrow ill run a TCU test . Replys are much apppreciated! At this point I don't think there is anything wrong with letting the guy take another look at it. Maybe someoen here will understand exactly what's going on with the car , I am ignorant of that issue- but in the real world, people make mistakes, its how they own up to and rectify them that shows quality. If he offers a reason it happened, realize that is not the same as an excuse. Only you can decide if he is 'excused'. But there may be an easily explained reason and perhpas it is due to a simple oversight like underfilling the tranny with fluid or some kind of reset/reprogram as suggested. let us know how it works out. Carl Quote Link to comment Share on other sites More sharing options...
ericem Posted April 21, 2006 Author Share Posted April 21, 2006 well there was definitly a little bit of grinding so most likely its low on oil. And i have been driving with torque bind for little over 20000km. My dad thinks they may have forgotten to connect a switch behind the pedal so when u floor it, it holds the gear. Quote Link to comment Share on other sites More sharing options...
nipper Posted April 22, 2006 Share Posted April 22, 2006 er um engine size, tranny type would help. What did the shop do to fix the torque bind nipper Quote Link to comment Share on other sites More sharing options...
ericem Posted April 22, 2006 Author Share Posted April 22, 2006 its a 2.2l 93 leg non turbo auto. according to him he changed the solenoids and clucth packs. so why would it affect my shifting? but i have driven over 200000with torque bind and dead drive solenoid. Quote Link to comment Share on other sites More sharing options...
nipper Posted April 23, 2006 Share Posted April 23, 2006 it sounds like he didnt hook up a wiring harness. Can you shift the car manually? Check your fluid level too. nipper Quote Link to comment Share on other sites More sharing options...
ericem Posted April 23, 2006 Author Share Posted April 23, 2006 even in manual mode it doesnt shift but when i didnt floor it i had no problem shiftings. but why would my speedo was bouncing. and my abs light came on. well he working on the car till tomorrow. so well c. Quote Link to comment Share on other sites More sharing options...
nipper Posted April 23, 2006 Share Posted April 23, 2006 HOLD IT! lets re-address this. When you drive normally the car shifts fine, that rules out the govenor. When the car is floored it revs up to 6500rpm, does it up shift, or did you get to that high an rpm and back off ? The spedometer is a kinked/ bad cable, or a bad VSS sensor. the ABS i dont know, unless the abs takes an input from the spedo head (i doubt it but who knows). I'm not sure how the power light functions, so i cant help there. nipper Quote Link to comment Share on other sites More sharing options...
