Need To Tow 1987 Brat - Question
Folks,
I have been in VA for the past 5 months (new job etc.). Just before leaving GA over the new year, the throttle on my Brat stuck wide open while I was driving @75 mph in Albany, GA. So I stopped the car, freed the throttle to a point where I could move it normally with my hands. The accelerator cable felt fine based on pedal feel after I freed the throttle. However, as soon as I started the car, the engine raced to redline, so I cut it off. It did this a couple of times. I believe something is stuck inside the carbureter. So I got the Brat towed home (Albany, GA) where it has been since January. Now I go back and move my family to VA next week. I plan on towing the Brat behind our 4WD Expedition, as the relocation company will not transport a disabled vehicle - and I have not had the time to rebuild or replace the carb. I am planning on getting a two wheel car dolly and towing the Brat with the front wheels off the ground. Is this acceptable and should I be wary of anything?
Thanks for your help.
aba4430
Did some searching, and am finding some information. Should be alright to tow with front wheels off ground, tranny in neutral and steering wheel unlocked. I might have an issue getting it on the dolly.
Just to be sure, you might want to remove the rear driveshaft as well. It's quick and easy, and will assure your rear end and tranny are disconnected.
No real need to pull driveshaft, unless it's got an Auto tranny. Then, you'll just want to disconnect it from the rear diff and tie it up out of the way, coat hanger works good for this. Need driveshaft in the tranny to keep the gear lube/ tranny fluid in.
As for getting a dead BRAT onto a tow dolly. Disconnect the coil wires so it won't fire off, and use the starter to get it up on the dolly. Again, this will only work if it's a manual, and you may have to put it into 4-low to climb the ramps.
I have used a floor jack under the engine crossmember to lift front wheels, then back dolly under vehicle. Doing it this way, you have to align dolly by hand then hook it to tow vehicle. Also need to block rear wheels so it won't roll backwards on you. Then push dolly under front wheels using tow vehicle. Need a good spotter to do it this way, but it works.
For the racing engine speed. Sounds as if your ASV grenaded on you and there's pieces of it in the carb. Pull air filter lid and take a look down the bore.
Also check the large vacum line that goes to the Anti-backfire valve, (located on the DS strut tower). I've had one of those break, causing major vac leak. Engine wanted to do a 3G idle if started cold with choke on. Rubber hose from the valve hooks to a steel line on the backside of engine, that's where mine broke.
Thanks for the responses. The tips on getting the Brat on the Dolly are helpful. It is a regular 4 speed DR transmission, so I do not need to disconnect the driveshaft. I will troubleshoot the carb. when I get home this weekend. I contacted Colorado Engine Rebuilders a few weeks ago to see if they carried carbs., and they don't. I read some recent negative comments about Roo Builders, so did not try them. Any good places to get a remanufactured carb? Plus do I need to be worried about repairing/replacing the ASV if it is shot? Lastly, when replacing the carb., do you need to drain off some coolant first? I read this in How to Keep Your Subaru Alive!
Thanks,
aba4430
if the starter works you might want to tell the transport company that. tell them it will load onto a car carrier or dolly and they may move it. if you just tell them "disabled" they may be thinking they can't move it to load, but that's not the case if the starter works. be a much nicer trip. i've towed cars from atlanta to MD, i'd get out of it if there was an easier way!
There used to be a guy down here who kept quality rebuilt soob carbs for the mudboat crowd in stock and sold them for $175 plus trade. Couldn't beat it.. But since his carb shop took in 12' of water during Katrina, he hung it up. Google is your friend... I did a quickie search and here's what I found:
Basic home rebuild kit on ebay - $17 plus shipping.
Rebuilt Hitachi DPC-306
FCproducts.com - $229 plus core deposit
Carbexchange.com - $269 plus core deposit
Importcarbs.com - $219 plus core deposit...
New
Weber 32/36 kit with adapter - $400 from several sources..
There's also a Holly kit out there somewhere, but I didn't bother searching for it..
Sometimes the quickie home rebuild kit is all you need to get another 20 - 30 thousand miles if it's not in too bad shape...
i got a reman carb from national carb.. works great, cost about $260
unhook your coil wire, and use the starter to crank it up on the dolly.. i know this is rough on a starter but if your not going more than a few feet, it'll be fine.. i've had to crank mine 100 yards+ before.. same starter is still workin fine..
when replacing the carb, you can either drain the coolant, or make sure the radiator cap is sealed.. the cap holds teh suction and doesn't allow the intake to bleed antifreeze, hehe..
other ways of getting your vehicle on a dolly:
ratchet strap
block and tackle
and my favorite a come-along
Thanks for all the replies. The kits are freely available through Advance Auto Parts as well as Autozone. Remanufactured carbs run $320 to $350 at the two stores. I am thinking if I get the car to Chestefield, VA, then I should have no trouble rebuilding the carb. Time is against my side, otherwise I would attempt a fix in GA. Will keep the group updated.
Regards,
aba4430
Folks,
I was looking into the carb. problem on my 87 Brat today. Took the filter assy. off and looked into the carb with a flash light and could not see any gunk inside. I charged the battery, then tried carb cleaner spray, and started the car (after 5 months of sitting idle). It started after a few tries and the engine raced towards redline. I cut it off and on several times to get some oil pressure. However, bottom line is I am stumped as to why the throttle is stuck wide open. The carb number is DCP306-26, but the Subaru parts catalog (85-88, 1600, 1800 2D & MPV) does not even reference this number. For a Fed-MT, 4WD model, it references a DCP306-24 model. They must have had all sorts of variations in the carburetor's for these vehicles. Went to Advance Auto Parts and they have the same part number for the DCP306-26 and DCP306-27. Best thing is to rebuild mine. Will keep the group updated on progress.
Regards,
Ashok
