SOOBOUTLAW Posted May 31, 2006 Share Posted May 31, 2006 I dropped a sweet 20k+ rebuilt motor outta my "83 parts wagon( I wanna fix if possible, but if you want parts, better rape 'er fast! PM me! ) into the Brat I just snagged for $900 (ripoff!) but driveable, and tha bizzle runs way better, yet the same ( won't stay running when warmed up, so, it"s not engine related, but I suspect the fuel system. The fuel pump has been replaced with a Facet (looks like it'll feed a hungry BB V-8). I have the same brand OEM size in my '80 wagon, bolts right on (NAPA), works awesome. Won't stay running when warmed up tho, WTH Bizzle!! (slap slap). I'm guessing dirty fuel tank (83 dirty girl Brat of course!) Maybe someone else has better experience of controlling your bit(#? Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted May 31, 2006 Author Share Posted May 31, 2006 Anybody? GD? You know your Soobizzle fo shizzle. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted May 31, 2006 Share Posted May 31, 2006 foshizzle my nizzle Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted May 31, 2006 Author Share Posted May 31, 2006 roll some fizzle, smoke some wizzle.... Quote Link to comment Share on other sites More sharing options...
Durania Posted May 31, 2006 Share Posted May 31, 2006 I bet Snoop Dogg has never heard of a Subaru. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted May 31, 2006 Share Posted May 31, 2006 doubt it,he might have seen them driving in teh woods, with there bling CB's and mad supa swampers,yo. Quote Link to comment Share on other sites More sharing options...
Will Smith Posted May 31, 2006 Share Posted May 31, 2006 I assume you changed both fuel filters also. You might try taking off the gas cap when this happens, if improved, a vent line is plugged. otherwise I'd guess pick-up screen in the tank in clogged. Quote Link to comment Share on other sites More sharing options...
HATCHY Posted June 3, 2006 Share Posted June 3, 2006 Ya dogg. Im a witness to the outlaws problem. I told him that i thought the fuekl pump was maybe to big.. I can hear it turn on when he turn the car over..its freaking loud like its huge... but the motor he put in puurs like none other that ive heard. no tick of death. no tick at all. and as soon as we start driving ( bog bog bog dead) starter cranks ... and then nothing.. its kinda of weak cuz I want to roll around in the Brat Quote Link to comment Share on other sites More sharing options...
HATCHY Posted June 3, 2006 Share Posted June 3, 2006 snoop dizzle wouldnt no how to handle a subaru hes used to the big snoopdeville. and like esclades and stuff were rolling these tiny old imports lol Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted June 3, 2006 Author Share Posted June 3, 2006 Just put the tank from the parts wagon in the Brat. Cleaned it out real good first though, some plastic crap was in there. I've been finding nasty stuff in my gas tanks for some reason. No more Arco. Quality fuel from now on. Now I gotta go disconnect some filters so I can blast pressurized air through the system to make sure the whole fuel system is clean before I hook everything up and fire it over. Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted June 4, 2006 Author Share Posted June 4, 2006 Took her for a drive today, nice and smooth until it warmed up and crapped out again. So far, I've replaced the fuel filters, then the motor, the ignition coil, fuel pump controller, the fuel tank, took the gas cap off, poured some fresh Shell premium in, and yet the problem persists. I'm stumped. Any new ideas? Maybe some kind of thermoswitch controlled thing? Quote Link to comment Share on other sites More sharing options...
fastenova Posted June 4, 2006 Share Posted June 4, 2006 How does the car act after it stalls? Do you have to crank it over a bunch to get it to start back up, with no throttle? Or maybe give it full throttle to start it up? I'm wondering if it's flooding or running out of fuel. Is it a carbureted or FI motor? If it's carb, do you have the choke hooked up? Did you keep carb from old motor or new carb with new motor? If carb is the same, is choke electric? Can you verify correct operation of the choke with it off the carb? Also, (I am not sure about the Hitachi, but...) my Weber has a little screen in the fuel inlet of the carb. Perhaps that's limiting fuel flow? Is your coil getting severly warm? Aaron Quote Link to comment Share on other sites More sharing options...
monstaru Posted June 4, 2006 Share Posted June 4, 2006 i agree with the choke theory.i chased a choke problem for days once.look at it this way,at least your fuel system is good now. Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted June 5, 2006 Author Share Posted June 5, 2006 How does the car act after it stalls? Do you have to crank it over a bunch to get it to start back up, with no throttle? Or maybe give it full throttle to start it up? I'm wondering if it's flooding or running out of fuel. Is it a carbureted or FI motor? If it's carb, do you have the choke hooked up? Did you keep carb from old motor or new carb with new motor? If carb is the same, is choke electric? Can you verify correct operation of the choke with it off the carb? Also, (I am not sure about the Hitachi, but...) my Weber has a little screen in the fuel inlet of the carb. Perhaps that's limiting fuel flow? Is your coil getting severly warm? Aaron New carb with new motor, Hitachi. I put it on the old motor before I pulled it to see if any difference, nope. I'll check the choke and coil. Electric choke is hooked up. Quote Link to comment Share on other sites More sharing options...
fastenova Posted June 5, 2006 Share Posted June 5, 2006 Try disconnecting the 12V line to the choke and see if it works. Easy diagnosis Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted June 6, 2006 Author Share Posted June 6, 2006 Choke works just fine, the negative insulator boot on the coil has a brownish spot on it, might be arcing. Gonna check the wiring. Might rip all the emission junk out and replace with what came with my parts wagon. The wagon ran just fine and drove good, but I didn't warm it up, just hastily parked it(front end damage, no radiator.) Also, the wagon just passed emissions in November before it got wrecked. Quote Link to comment Share on other sites More sharing options...
