June 24, 200619 yr by removing his front halfshafts, still leaving the outer spindles in to hold the front end together. this would make the car rear wheel drive. also these cars have front emergency brakes, so just set the emergency brake and dump the clutch in first:D subes are so light in the rear, i bet a stock sube set up in rwd could do just as good of a burnout.....
June 24, 200619 yr I've gotten to second gear. Gotta melt the tires greasy and double clutch. And buy new tires.
June 24, 200619 yr the *ahem* leash is so someone can let him know when his time is up, they give him a tug and he's supposed to stop.
June 24, 200619 yr What's really fun is to get it spinning on dirt, cut the wheel, and walk the car around. It works better if at some point an axle was installed in contact with the parking brake cable, locking it in place so only one side works............
