semi-emergency: Pizza Man Needs a Bolt-size
hey all.. 87 gl-10 A/t.. i just checked under the hood and the rear bolt that secures the A/C compressor and alternator bracket to the block is MISSING!:eek:
i am going in to work a busy friday night in hot south florida, if ANYONE can reply to this thread with specific bolt and thread dimensions i can stop at a store and buy a new one to put in, but i need this ASAP so my roomate can check the thread and update me.....
thanks in advance for the answer, im sure someone here can tell me...
peace,
shawn
RANDOM GUESS: 10mm x 1.25 pitch
pitch i am sure of...diameter not so much.
often you can pull one that's not quite as necessary from somewhere else and put it where you need it.
is it causing any issues?
I think Gary is right about the size.
I used to have the same problem with the same bolt (I even have the same car)
I found out that the bolt that was in there is just slightly too long and was bottoming out before it was truly tight. A small lock washer added to the equation and its been there for three years.. only coming out when I tell it to :)
I think gary's right also....I do know that it's a 14mm head. and only 1.5-2" long.
