EJ22 no-start...crap...
1992 Legacy. It's got plenty of gasoline, it turns over...but it don't fire up. It's got new plugs and a healthy battery. ????????????
Flywheel?
Starter?
eh?
HELP!
Timing belt?
Oh yeah...
I'm an idiot...a big one...
Wait, what if it's not? Any other ideas? (Not that I don't believe you...)
Crank or Cam position sensors. Assuming it's not a hot start issue.
If its got air, fuel, and spark......it should run (unless the t-belt is all done, or JUMPED time)
Everything else I can think of would just make it run poorly.
.....or that :-\
Lets start with basics, do you have spark, and if you do is it a strong spark..
nipper
Open your gas cap and put your ear there while someone turns the key on, and listen to see if the fuel pump runs for just a few seconds. I just take the line off at the filter and turn the engine over but this can be dangerous, the other way is safer.
